Microsoft Windows Vista Home Basic for PC Logo
Question about Microsoft Windows Vista Home Basic for PC
EXPERIENCING SOUND PROBLEM
I tried looking at a movie on my lenovaG530 but there is a sound problem i cannot hear the words can you tell me what is the problem and how it can be solve
Posted by misstom_ap on
Anonymous
    Scholar:
  • 63 Answers
1.Look in the lower right corner of your screen, does the speaker icon next to the date and time have a red circle with a line through it? If so, right click the speaker icon, open volume mixer, and click the speaker icon for device to un-mute the speakers.
2.If using Windows Media Player (I am sure this applies to other media players too) please check below the video which is playing and locate the volume control slide bar. There should be a Speaker Icon next to the bar, make sure the red circle with a line through it is not on this icon either. If so, click it to un-mute your media player. Also, make sure the volume within your media player is turned up in this same place.
3.Finally, if all else fails, click the windows bubble (start menu) and right click on "Computer" and click "Manage". Select "Device Manager" from the list on the left, and scroll down to "Sound, Video, and Game Controllers". Expand that list, if you have any errors (Yellow Triangles, Red X's) there, you will need to reinstall drivers which can be obtained from Lenovo's website.
Posted on Feb 25, 2010
Anonymous
    New Friend:
  • 64 Answers
It sounds to me like a codec problem, read this blog, it talks about the codecs you need
http://simontodd.com/2010/02/how-to-fix-the-problems-when-playing-a-movies-on-my-pc/
Posted on Feb 24, 2010
1 Related Answer
Anonymous
  • 239 Answers
SOURCE: i tried looking at a movie on my lenovaG530 but
Hello.
Well please check if audio is mute on Windows media player or the other player that you are using.
You can go to start/all prog/accessories/ entertainment/volume control
Here you can uncheck any mute boxes.
Please send us your vote and feedback.
Posted on Feb 21, 2010
1helpful
Background sound often is so loud it drowns out conversations. Often occurs w=in a movie when there is some background music and dialog. Cannot hear the dialog. Has occurred when watching live music. ...
Looks like you have inadvertently enabled some sound effect, usually these effects can be enabled/ disabled form sounds menu. They will have names like surround, movie hall, concert etc. Go to the sound settings and disable any activated audio effects.
I have a Pioneer VSX-D510 reciever with 5 speakers and sub. The sub keeps making continual popping sounds at higher volume levels when watching movies, tv etc. Have to turn most of the way down. Also,...
Manuals help a lot.
Tell us about the speakers. Maybe they're not compatible.
As far as what to expect to hear from surrounds, that depends on the sound engineering.
Test tones for speaker setup will get it all dialed in. Page 17.
Hello.
Sound doesn't match the movie?
Look at the settings on the DVD/Receiver you are using. There is an option for adding a delay between the movie and the sound. Try to adjust that.
2answers
Hear sound for dvd
there should be a wiring harness from the dvd player that plugs into speaker wiring harness and is controlled with stereo volume
9helpful
2answers
I can't hear people talking when i watch a movie?
I had the same problem and found that there was a connection problem with the center speaker. Do a sound check on all speakers and see if the sound is coming out of the center one. If not then just check you have connected it properly.
2answers
Audio device problem
hi.. sir
please follow the step's
1. start
2. control panel
3. sound and audio devices
4. voice
5 test hardware
6. follow the step next ..
itwork's is ur audio device is correct.
thank u
sir don't forget to rate it..
No sound on movie playback
This camera does record sounds. But, it doesnt look like it has a speaker in it to play them. So, yes unfortunately you wont be able to hear what you record unless you are using something else to playback what you have recorded.
Good Luck.
Static 'white' sound
Good day.
Try to remove the cover of your unit and clean the tube with a dry cloth. try to look for the anode cap. the one tht is connected to your tube if there are holes in it. This causes the problem.
response is highly appreciated,
chris
Top Microsoft Computers & Internet Experts
David Shaub
Mehandi Husain ...
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
