Question about Sony XM-2150GSX Car Audio Amplifier
When i turn my amp up it goes into over current / offset mode and doesnt come back on until i turn the radio off and turn it back on
Posted by chrissidney2 on
Anonymous
    New Friend:
  • 24 Answers
Ive never liked xplodes it always did that to me..check youre wires make sure they are the correct gauges...if you buy an amp always buy from a dealer and make sure they install it correctly ...
Posted on Feb 24, 2010
I have a 2002 dodge caravan and nothing thats powered from the ignition such as radio, wipers, turns, blower etc, is working, also the battery is being drained within a day
First, remove the battery - charge it fully, then load test it. If it tests good. Set the battery back in the battery compartment and connect the positive cable. Then run a test light (you can get a cheap one at harbor freight tools) between the negative battery terminal from the car to the negative terminal on the battery (basically complete the circuit with the test light in the middle). If you have a big current draw, the test light will light. If the test light lights up, leave it connected and go to the fuse box and start from the top and remove and install one fuse at a time. Do this until the test light goes out. When the test light goes out, you'll know what circuit your problem is on.
Go here http://www.bbbind.com/free_tsb.html and look up the wiring diagram. then put the fuse back in and start removing components on that circuit (for example, if the radio is on the same circuit just go down the list of items connected to that circuit and disconnect and reconnect one at a time until the test light goes back off), when it goes off, you have found your source of current draw.
If you start this process and the test light does not light during the first step, you will need a DC Amp Clamp meter to read the smaller current draw (sears has a AMP CLAMP METER that does DC AMPS for around $50). In this case, you would connect both battery terminals (connect positive first), then use the AMP CLAMP on the DC AMP setting to read the current draw and repeat the same process as mentioned above.
Please reply if you have any further questions.
Hope this helps!
On my yaesu ft-757gx when I key up then speak the output goes to zero,the dial goes black sometimes relays click and the mode switches to lsb until the key is released.
Sounds like the power supply is faulty and dying when the transmitter demands current. Perhaps a loose connection or dirty relay contact.
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
2helpful
2answers
1helpful
2answers
My Sony XMGTR2022 goes into protect mode at
I discovered that there is a compatiblilty problem between the Bose receiver and the Sony amplifier. If I disconnect the receiver from the amp then the amp starts up normally. Apparently the receiver sends out a dc offset or a "thump" that the amplifier doesn't like and goes into protection mode. I solved the problem by putting a 1 second delay circuit between the receiver startup and the amplifier startup. A simple RC delay on the remote input to the amplifier solved the problem.
My car got a buster jump yesterday and now my screen doesnt work
Make sure you have the radio code found inside your model information packet inside your glovebox…it will be on the radio and communications pamphlet. It is in safe-mode right now, so press and hold the FM button and the scan button until 1000, or whatever number is stored in your safe mode, appears. Enter your code by selecting the pre-set radio station buttons until the corresponding number appears; press and hold the FM button and scan button again and your radio should be reset.
760 sony explode amp in protection mode
I have a Sony X-Plod amp 760w 2/1 channel xm-1902gx. Everything is connected properly and the amp contains 4 lights (power,over current and two others). Power lights up like it's supposed but the over current lights up as well. I am unable to get any sound from it. Can you help me before I trash the amp.
Sony xplode 1 olm amp problems
check were you plugged the input to a high or low, giving an amp too much signal will do what you described, certain amps got a limit.
Fusion Amp Starts In protected Mode
check remote wire coming from back of radio
Sony XM-2150GSX Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
