Need to clean sensors in amana 80 sse furnace, where are they located?
Posted by cindycook52 on
Anonymous
    New Friend:
  • 66 Answers
The flame sensor is usually on the opposite side of the ignitor, and held down with a 1/4" screw with one wire connected. It has a metal bracket and a piece of porcelin with a metal ,round strip of metal through the inside of it.
Posted on Feb 22, 2010
Will a wireless thermostat work with my amana command 80 sse furnace?
Yes. A wireless thermostat will work on your Amana furnace. I like the Honeywell wireless thermostats. The only problem I have had is exceeding the distance between the wireless thermostats location and the control module that you mount and wire up next to the furnace.
Feb 07, 2018 | Amana Heating & Cooling
Amana model ACS4250A (slide in). How do I remove the front panel?
[PDF]80-90 FURNACE SERVICE MANUAL.pdf - Johnstone Supply
johnstonesupply9.com/.../Amana/Gas%20Furnaces/GCCA%20Gas%20Fu...
Instructions. This manual is to be used by qualified HVAC technicians only. Amana .... Gas Furnace Upflow/Horizontal Induced Draft A Air Command 80 SSE.
Nov 06, 2015 | Kitchen Ranges
My Amana Air Command 80 SSE IIQ Gas Furnace started up for a few seconds the shut down with no indicator light. I went up and switched disconnect off and on, then checked all connections and fuse on...
Have you cleaned your flame sensor? Take a piece of emery cloth or a piece of light sand paper and sand it a little. It is located in the burner section and it is usually to the left side of the unit and it looks like a L. Hope this helps.
Feb 13, 2012 | Heating & Cooling
Amana 80 sse
Amana aircondition window unit wouldnt turn on. E2 indicator light was on. I turned off breakers and turned them back on as suggested for an Amana furnace. Yay, it works now. Thank you.
Jan 19, 2012 | Amana Heating & Cooling
Amana Air Command 80 SSE gas furnace will not stay running
In the path of the flame on the last burner that starts, there will be a small rod. That rod is the flame sensor. Take a scrub pad and polish it. Also check the electrical connection that goes back to the circuit board. Disconnect any ground wire from the circuit board to furnace cabinet, sand it and replace it.
Mar 14, 2010 | Heating & Cooling
My amana 80 sse furnace will not heat. looks like furnace light is off. what can i do to reset it. thanks
Turn off breaker. Turn it back on. If furnace is completely dead still, change your transformer. It's cheap..
Dec 11, 2008 | Heating & Cooling
Need to know what size Blower motor I need for and Amana SSE 80 furnace.
The blower size is selected based on the details of your home. The size of the motor must match the tonnage of the A/C. The tonnage of the A/C will be determined with a heat gain/loss calculation.I believe there are at least 2 options for this furnace 3 Ton, and 4Ton.
Jul 02, 2008 | Amana Heating & Cooling
Furnace manual
here's the link for your problem and I hope that it helpshttp://johnstonesupply9.com/TechDocs/Amana/Gas%20Furnaces/GCIC%20Gas%20Furnace/GUIC%20GCIC%20TECH%20INFO.pdf Thanks for unis FixYa!
May 26, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
1,400 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
