Question about JVC KD-G310 CD Player
Is there a way to link a JVC Kameleon head unit with my stock CD changer? I have a mercedes slk350, just replaced the audio 20 head unit with the JVC Kameleon. Everything works and looks good, but I want to try to keep my stock CD changer. Is there any way to link it to the JVC?
Posted by kmatthews884 on
Anonymous
  • 518 Answers
The only thing i can suggest is to go to your audio shop and ask the same question to them, as they normally carry many different styles of leads and may have one there that will help you to connect your cd player, Is there a din output on the back of this unit? if so they should be able to help.
Posted on Feb 21, 2010
I have a jvc-x11 cd changer is it compatible with my sony MEX-BT39UW
No, it won't work. JVC changers work with JVC head units, Sony head units work with Sony changers. Even if the plugs are the same, it won't work.
Jul 28, 2015 | Sony Car Audio & Video
Cdx-705
Most cd changes only work with like brands. Sony with Sony .jvc with jvc. Find a manual for a brand new model on google or the the manufacturer and see if it has a problems section
Dec 27, 2013 | Sony Cdx-705 10-disc Intensified Shock...
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Hey guys, I've just installed a CD changer in my car - having some difficulties getting it to work. After some Googling I came across this forum so I figured I'd see if any of you guys know where I'm...
there should be a small connector on the changer itself for the power ground and remote wire for power to the changer unit. the cord coming from the unit to the changer doesn't supply this power and this is why it wont eject and also your head unit wont recognize it until it gets powered up and able to communicate with the head unit and then it will show up as a selectable source when switching between sources of music. check the back of the changer for a small connector containing 3 or 4 pins and you should have a connector with the corresponding wires coming from it to plug into this spot after connecting the wires properly. if you bought it on ebay it is possible you didn't get this piece which is critical when connecting this changer.
Apr 03, 2011 | JVC CH-X1500 12-Disc CD Changer
I have a 98 ford expedition. i am changing the stock tape deck to a jvc cd player. i am getting power to the new deck but no sound. i have a stock 6 disc changer in the arm rest of the car. would this have...
its simple that model may be equipped with factory amplifier and cannot transmit to speakers unless bypassed and wired directly to speakers after amplifier but if unsure go to crutchfield.com and get help! or call local audio dealer. Also if you purchase wiring and installation kit it will bypass that.
Jan 26, 2009 | Car Audio & Video
Rockford and fostgate
i dont think different brands ar compatible as such.
Dec 01, 2008 | Rockford Fosgate RFX-8030 CD Changer
JVC Daisy Chain
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
Feb 22, 2008 | JVC KD-G421 CD Player
JVC KD-G310 CD Player Logo
94 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
