Question about Denon AVR-587
My very old Denon AV Receiver (DRA-55V) works fine except that one of the channels sounds 'gated' or thuddy and staticy...music is heard (in all sets of speakers and headphones) but quality in one channel is shot to hell. Any ideas?
    New Friend:
Check your speaker A - B channel push-button switchces. They tend to get worn and contacts internally corroded after all these years <!-- from fixya rte -->
Posted on Aug 16, 2010
Can it drive 4 ohm speakers?
If you connect 2 4 ohm speakers in series it will work. You shouldn't try a 4 ohm by itself. You'll kill the output stage of the amp.
Jan 06, 2014 | Denon Dra-55v Precision Audio Component/av...
My denon DRA-295 does not remember stations I set to memory when completely turned off. If on standby all goes well. A month after the problem mentioned above the tuner started to modulate reception and...
My better guess is a CMOS chip is either bad or there is a cold solder connection in the vicinity. If the power supply is bad, the receiver would not power up.
Nov 23, 2010 | Denon DRA-295 2 Channels Receiver
I want to know how many watts, the denon dra-375's output is? my brother-in-law gave me this unit and the cover's became diattatched off the back of the all the pot's. i am still in the process of putting...
The unit is rated at 120 watts total output ( 60 watts per channel x2 channels) As far as being worth fixing it depends on the price of the parts and what you want to do after its fixed. I looked around a little and the unit gets good reveiws from owners. They say its great for a "just music" system.
Jul 28, 2009 | Denon DRA-375RD Receiver
Denon Receiver, DRA-625R, Stops after 3 - 5 seconds
If you like the sound (when it works), then yes it is worth fixing. There are a number of possiblities for this symptom. Can you supply a rough location so I can recommend a local shop for you?
Thanks,
Dan
Mar 13, 2009 | Audio Players & Recorders
No sound from a yamaha AV receiver preouts connected to ext in
Do not use the ext in plug into the aux, or video input of the denon
Jan 28, 2009 | Denon AVR-3300 Receiver
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
Denon AVR-587 Logo
794 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
