Question about Dirt Devil M086700 Vision Bagless Upright Vacuum
Dirt devil bagless will not ****. i have ensured entire suction path is clear. motor sounds normal. belt/brush are working fine. filter is clean. can i fix this myself? cost only $50 new so i probably won't take it anywhere for service.
Posted by chaucraig on
A Miller
  • 8,404 Answers
If it is completely clean, no strain on the motor, no clog, check the fan on the motor - Intact? ... or is the center pulled out of the fan?
Posted on Feb 21, 2010
  • wthillers Apr 27, 2014
    Hey, I'm having same problem with my Dirt Devil Reaction. Everything seems fine, except that the suction is so weak I can't even lift dust off the floor. A Miller, what is the meaning of your suggestion to check the center of the fan?
Got a dirt devil upright I've cleaned out the Short hose extension hose also cleaned under bottom plate checked belt looks good don't see no holes or cuts in hoses no cracks in bagless container
Hello, Im assuming that your unit has no suction. If this is the case, it is still plugged. Run a stiff wire through all the hoses, starting at the on behind the bristle brush. Make sure all the bagless filters are completely cleaned.
Mar 30, 2017 | Dirt Devil Vacuums
The vacuum is hard to manuever; too much suction sound for less suction quality; I've cleaned the unit and replaced the filter. Is it the belt?
Probably it is but vacuum motor and its associate mechanical parts should also be check and clean.
Clean the motor, if suction is still less, then the motor brushes is already wear and need to be replace.
Put back what you disassemble and bring it back together. You must be observant when doing that.
Thanks for asking.
Jul 07, 2011 | Dirt Devil Featherlite Bagless Upright...
I have a Hoover Windtunnel UH70212. Just a few months old. I used the attachments a while back and now there is very little suction. The power brush attachment doesn't work at all. Any suggestions?
If there is no suction, there has to be a blockage somewhere in the dirt path. You should hear the motor working a little harder in this condition. Please check the entire dirt path from floor to exhaust (clean all filters too) to find the obstruction.
Thanks for your question @ FixYa.com
Mar 13, 2011 | Hoover U8341-900 WindTunnel 2 Bagless...
My dirt devil breeze shoots out dirt from vent
try cleaning the filters and clear out hoses, sounds like it has backed up inside, also if the filters aren't clean it can loose suction.
Nov 01, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
I have a dirt devil featherlite bagless vacuum; model #088600. It has suction through the hose but not through the floor mode. I think there is a blockage in the hose area but cannot seem to take it apart...
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
May 03, 2009 | Dirt Devil Featherlite Bagless Vacuum...
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Suction
make sure the brush roller is turning.if not the belt ie either broke or it might have come off the motor shaft.feel free to call me at 314-628-9153
Jan 26, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Suction problem
sounds like you have a leak in the suction path
look for a broken hose or seal
May 21, 2007 | Dirt Devil M086700 Vision Bagless Upright...
Dirt Devil M086700 Vision Bagless Upright Vacuum Logo
384 people viewed this question
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
