Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
<span style="font-weight: bold;">Airgle Air Purifier:</span><br />
<ol>
<li>Turn off and unplug the unit </li>
<li>Press the light button to the "on" position </li>
<li>Plug in the unit, and then release the button after the Filter-check starts</li>
<li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li>
<li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li>
<li>This time, the system should report an accurate result.
</li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br />
<ol>
<li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li>
<li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br />
<ol>
<li>Units which have an indicator light must be
reset once the HEPA filter has been replaced. Reset indicator by inserting
a small object (such as a pin
or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br />
<ol>
<li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br />
<ol>
<li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br />
<ol>
<li>Change the filter and/or pre-filter.</li>
<li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li>
<li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br />
<ol>
<li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li>
<li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li>
<li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li>
<li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li>
<li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li>
<li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br />
<ol>
<li>Press the FUNCTION and OFF TIMER buttons at the same time for five
seconds. The CHANGE FILTER INDICATOR will flash five times and turn off
</li></ol>
I had similar issues and by replacing the 2200 micro (Mu) Farad, 10 Volt capacitor on the PCB, all of my issues ceased.
Below is a link with information supplied by "fixya" that explains the procedure/details.
Hopefully this will solve your current issues.
Good luck,
Mike http://potlash.org/feast/2010/11/20/repairing-a-jet-afs-1000b/
PS Linda Haus of "Rockler" Technical Support was kind enough to supply me with this link.
The water level sensor fell into the fan. Unplug the humidifier from the wall, stick your hand in between the fan blade and locate the sensor. It is a small black rectangular piece the size of a nickel but rectangular and 3 nickels thick. It also has a 2 inch stem sticking out of that clicks back and forth when you push it. Stick the sensor back into the sensor whole and the flashing f will go away and the humidifier will come on again.
Oops. It's possible that the incorrectly inserted plate caused the machine to malfunction. It may need to be sent to the factory so the computerized controls can be recalibrated. Call Vollara (new name for EcoQuest) Customer Service 800-989-2299.
I would check the wiring connections to the fan and to the display board. Make sure they are seated properly. If that does not fix it, then call your dealer or the company and see what options you have. The company number is 800 989 2299.
i do apologize for the inconvenience the only thing that i can suggest is the that whole unit will need to be reset. so the machine can connect again with the remote. also make sure that batteries are fully charged. If that doesn't work please let me know.
