Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Winding like a motor trying to be started, over
Gas Heater motor making a noise like a winding motor trying to be started, over and over again, with a burning smell coming from heater vents, flood in basement, water running out of basement heat ducts. there is lots of snow melting outside. Any ideas anybody? Thank you!
Posted by sweetnjte419 on
Anonymous
    New Friend:
  • 66 Answers
You probably have water in the bottom of the blower housing, and need to remove it and empty it. Be "VERY" careful, because water and electricity do not mix. if you cannot do it, you should call a furnace company to check it and give you an estimate. Also. make sure the power is off before even touching the unit.Your situation "IS" very dangerous.
Posted on Feb 22, 2010
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
Dryer stops running shortly into cycle. When button is pushed to restart, dryer groans. Holding button may get the unit going again - but it makes noise running and stops again soon. Bad motor? Bad...
Sounds like start winding switch. I would replace whole motor assembly. Try on ebay for a used one that looks newer. Used motors will save you some serious money.
Jun 21, 2010 | Speed Queen AES28AWF Electric Dryer
Light flashes, clicking noise, fan does not turn
it sounds like the motor has a weak start winding or if the unit has a start capasitor it is bad
Feb 05, 2010 | Reiker Room Conditioner Ceiling Fan with...
The freezer stopped and compressor is making clicking noises
The compressor motor has seized up and what you can hear is either the thermal overload switching off the motor when it realises that there is too much heat being generated by the stalled motor or the start relay trying to hit the start windings with a new voltage and failing to do so.
You can obtain a new compressor motor which will also mean a re-gas of the system
Oct 05, 2009 | GE PFS22SISSS Stainless Steel French Door...
Will not Start the Blower/Heater or tumble
HI, it sounds like the motor might be bad. TRY open the door, while someone is holding the door switch and pushing the start button, Try and turn the drum with your hands. If it starts, the motor winding is going bad.
Please let me know if this helps you at all or if I can assist you further.
Vic
May 28, 2009 | Maytag PYG2300A Gas Dryer
Pilot makes wind noise
pilot dirty or to much gas pressure to pilot or problem in venting
Feb 19, 2009 | Reddy Heater RLP100 Portable Forced Air...
Dryr starts to crank up than just stops and wont turn on any more
Hi there, this is motor failure. the actual motor windings are in bad condition at this moment. they are separating and this can ultimately start an electrical fire. the automatic shut off prevents the fire form occurring. you will have to remove the motor and tanke it to an electrialc motor shop for a re thread.
Feb 17, 2009 | Whirlpool GGX9868J Gas Dryer
Air con gas leaking & noises from under dash
Hi jrm the smoke under the wing is the fuel fired heater and is normal. the noise is the heater motors for the heater flaps, there is a jag fix but you have to replace all the motors just ignore it.  Try changeing the filter for the heater under the left side scuttle panel thats below the black plastic panel below the screen that will help the steaming up     D
Dec 30, 2008 | 2003 Jaguar S-Type
Kenmore Dryer
sounds like it may be overheating.. Might try to take apart and see how much lint you got built up on the motor... may be causing overheating Is this the ONLY time it makes the humming noise when you go to start it??? May also be the early warning of bad start winding or start relay on the motor
Sep 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Matag dryer does not run, but for a while it hummed before starting.
Motors of this sort have a "start" winding, to give them an extra boost to get them turning. Once they're turning, the start winding shuts off. Critical to this is the start capacitor which, when shorted, causes the exact symptom you've described. The motor's "regular" winding gets power (and then hums), but it needs that extra boost to actually start turning. Have someone check the capacitor (with an ohmeter) or check to see if the motor's start winding is open (broken).
Apr 10, 2006 | Maytag HYG2460AWW Gas Dryer
Heating & Cooling Logo
77 people viewed this question
Top Honeywell Heating & Cooling Experts
Paul Carew
Sean
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
