I bought a hts 3345 system with out the sub and just got a sub for it, i hooked it up togeather and the sound is clear but very low on max, can you help please
Speakers are an integral part of any home thetre system and are, as such, effictively useless without them. You will need to attach some speakers to it in order for it to work as intended.
In general higher speaker impedance is safer than lower impedance for the amp. Don't expect anything impressive re: audio output from a passive (unpowered) sub if your HTS says it pushes only 25 watts. Without frequency bandwidth and distortion noted the spec is virtually useless as a comparison.
The BU-1 is a powered sub that accepts either RCA Line Level or HIGH LEVEL amplifier power. If you use the latter, impedance is a non-issue because the input feeds the BU-1's internal amp, not the speaker directly. You should be okay.
Perhaps if we knew some specifics about the HTS we could do more than guess.
Does the Sub have a Low- Level input? This is a RCA type female connector, what you need to do is run a Male RCA cable from your home theatre where it says Sub-OUT and go into the Sub woofer Line in. Unless you only have speaker wire inputs on the back of the Sub then take the Left and Right front into the Sub speaker inputs and then out of the Sub speaker OUTS back to your speakers.
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
See what audio outputs your tv has. See if your HTS has matching inputs. If it does connect them with the proper cable(s). Connecting to the tv should cause your HTS to work with anything you are watching on the tv.
Did you connect your TV to the DVD player via video cable (S-video, composite, or component)? That might be why you cant see the screen and stuff. To connect to TV, just connect your VIDEO OUT on the dvd player to the VIDEO IN on your TV. About that sub...you can hook it up, but it will only have as much punch as the player will allow. In other words, dont expect much out of a 20" sub if you have a 100 watt system.
