Question about Polaroid TLA-01511C 15 in. LCD Television
My Polaroid TLA-01511C has sound but no picture...what do I do
Posted by p_f_dorsey on
  • victorwong Feb 24, 2010
Chi Chu
  • Polaroid Master
  • 8,457 Answers
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Posted on Feb 21, 2010
3 Related Answers
jaime vargas
  • 476 Answers
SOURCE: sound no picture Polaroid 15.4 TLA-01511c
If you take a good look at the screen when it goes dark can you make out anything maybe some bright scenes on the channel you were watching or if you press the menu key, you can see a very dim display, you might need the back light assembly or something related to it.
Posted on Jan 09, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: i have a Polaroid 15.4"
No picture can be due to bad inverter circuits. This is an 15" TV, so more likely to be the same as 15" PC monitor with an added Tuner.
Bad cap can look normal but can have high ESR.
You need to find out if the inverter circuits is getting the 12~16vdc feeidng it, also see if the backlights even flashes on at all.
To repair down to component level will be difficult without diagram but can be done but with a lot of times needed.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 25, 2011
Anonymous
SOURCE: I have 3 Polaroid TLA-01511C 15 in. LCD Televisions
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Posted on Nov 29, 2009
I need the manual for a polaroid tla-01511c manual free
Try Googling (polaroid)(tla-01511c)(manual) without parens.
Sep 25, 2017 | Polaroid Televison & Video
Sound no picture Polaroid 15.4 TLA-01511c
Jan 09, 2010 | Televison & Video
I have a Polaroid TLA-01511C 15 in. LCD Television that has no picture but does have sound. Solution #1 in this page says "a bad cap in the power board, the can like device will have a puffed up top from...
Radio Shack is your best bet. I replaced two 680uf 10v caps and one 1500uf 10v cap. It now works just like brand new. The caps I replaced had higher voltage values hopefully this will help prolong the life of them.
Nov 27, 2009 | Polaroid TLA-01511C 15 in. LCD Television
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Problems with Polaroid TLA-01511C 15 in. LCD Television
It needs a video board replaced most likely. You can find by searching on google for your model. Might cost more than set is worth. Think about new model as they are really cheap in that small size.
Feb 04, 2018 | Polaroid TLA-01511C 15 in. LCD Television
Manual for TLA-01511C
olsonde,
Here is your product info. Please let me know if I can help you in any other way! If not, I would appreciate you rating this as "FixYa".
http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT261&folder_id=0
-DRebel
Apr 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
Feb 23, 2009 | Polaroid TLA-01511C 15 in. LCD Television
How do i find the AUX on the Polaroid TLA-01511C? I want to run a DVD player and it needs to be set up on the AUX. If I run a scan on the channels it does not pick up the AUX
I would recommend using the S-video connection for the DVD to the TLA-01511C TV's S-video. Then, press the input button and go down to the S-video option and you should be good to go - it worked for me. Hope this helps you!
Dec 21, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-01511C 15 in. LCD Television Logo
730 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
