Question about Moen & One Handle Tub & Shower Faucet
Moen single stem bathroom basin tap (25 years old). Trying to remove cartridge to grease it or replace it. Have removed handle and retaining clip. Pulled hard but can't shift it. Don't want to break anything. What's the trick to doing this, please
Posted by martyn_phill on
Anonymous
    New Friend:
  • 35 Answers
You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
Posted on Feb 23, 2010
The spout on my Moen 7700 kitchen faucet is very "stiff". Do I need to get plumbers grease into it to loosen? If so, how? I've tried dropping the nuts under the unit beneath the sink and am still
you need to remove the moen cartridge. first, remove handle. at the top of stem, there is a U shaped retainer clip. it hard to see,use a small knife blade to catch the closed side of clip and slide clip out. once clip is removed, you should be able to pull cartridge out with a twist and pull motion. if it wont come out,that way dont pull to the point where you brake cartridge. that means replacing faucet. in extreme cases, you ca buy a moen stem puller for about $15. once stem i out simply coat with stem grease and replace cartridge. when replacing retaining clip, keep a pushing in pressure on end of stem to allow clip to slide into place. it iseasier to do than it sounds
Dec 02, 2012 | Plumbing
No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
Soak the dirty cartridge in vinegar for four hours and replace.
If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
How do I repair a dripping Moen M4600 (1978) bathroom faucet? Looks like the Moen 1 handle 64621P that is pictured here. Thanks. Richard
First shut off water supply and remove cover on top of handle.They generally just snap in place so you can remove with screwdriver or knife point. Remove screw in center of handle and pull handle off. There is a copper retaining clip that holds cartridge in place. It has a small hole in the center on top that you can insert scratch awl or other pointed tool in and pull straight up to remove.You can try to grasp center stem of cartridge with pliers and pull up to remove. If the cartridge has not been changed for a long time it may be very hard to remove.
You are going to have to replace the entire cartridge so you should have one on hand and you can purchase a tool made especially to remove moen cartridges.Just follow direction that come with cartridge or tool and remove cartridge. I would use the brass cartridge as I have not had good results with the plastic ones. When you get old cartridge out I would use a small amount of faucet grease or petroleum jelly to lube o-rings and then reinstall new cartridge and clip,handle,screw,and cover. Good luck and thank you.
Dec 28, 2010 | Moen 1 Handle LavatoryWith Drain Assembly...
Need to change washer faucet
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
Followed replacement procedure for moen posi temp shower valve (turn 45 degrees ctr clockwise after removing retainer and pull) valve will not come out.no matter how hard i pull..what next (solution ???)
Often time a Moen cartridge becomes very fond of it home and doesn't want to leave. I once stood on top of a kitchen sink just to get my back into it to remove a cartridge. That is a rare example.
Once the retainer clip is removed there is nothing to keep the cartridge in place except water minerals, lubricant, and suction caused by the lubricant. Frequently it will take a rocking back and forth of the cartridge to fully free it from it's confines before a good tug. If you don't use the white plastic tool that comes with the new cartridge, you could pull the center stem out only and that's all bad. Before installing the new one see if you can have someone turn on the house water for an instant while you hold a cup or glass over the hole for the cartridge. This will flush out of the valve body any particulate that might affect your new cartridge. The cup will help keep you and your bathroom floor dry.
After inserting the replacement as far as you can, place the tool back onto it and tap on it to make sure it is in all the way. Then use the squared end to put a wrunch on to you can turn the cartridge internally and align it for the retainer clip.
May 21, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Nov 27, 2008 | Plumbing
Moen & One Handle Tub & Shower Faucet  Logo
411 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
