Question about Philips 37MF321D 37 in. LCD Television
Turn itself off as soon as you turn it on (37MF33ID/37)
Posted by bryantderik on
Anonymous
  • 3,741 Answers
In the lcd tv there are three main parts
1)the inverter board(pannel)
2)the main board .
3)the power supply board.
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is ON then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
but if there is just front led light blinking , but no picture or sound then its power supply board problem.
but as you mentioned that the tv turns ON for some seconds then automatically turns off this indicates that the power supply board is not faulty but there is a component on the board that is getting over heated because its got weak so due this overheating of a component the circuit gets short and tv shuts off.
on power supply board there are some capacitors and ic located.if any of the component gets short or budged up then it short the power supply board.so you can check the components on power supply board with multimeter and get it replaced by using soldering iron.
also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Feb 20, 2010
37mf33id 37
try holdimg the power button dowm for a min, or so
1helpful
MY VIZIO 37 INCH TV
I think you may have the same thing going on that we had happen several times, I think its stuck in RGB mode. Go to the TV itself, and turn it on manually. As SOON as you turn it on, hold the input button on the side of the TV for 30 seconds. This should get it back to the normal TV mode. We got this fix from Vizio ppl.
It seems like the volume down button is stuck. As soon as you power on the set it turns the volume down all on its own. I've check the button itself and removed the batteries from the remote. Don't know...
Try some contact clean on the Vol- and Vol down contact switches,either the Vol- contact is dirty or it needs to be replaced. Mats Electronics has contact switches 1-800-628-1118
You could have a problem with Poor Solder Connections on Boards.
1helpful
The magnavox hdtv model number 37mf33id-37 will not come on but the green light flashes above the on /off switch
Tries tv unplug,replug it back like about an hour later.Now the tv should be resetting itself back to the factory setting.The tv now should work again.If not the problems and the causes is the tv power supply board problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
37 inch magnavox tv green light blinks won't turn on.
www.p4c.philips.com/.../42mf521d_37/42mf521d_37_pss_aen.pdf
http://www.eserviceinfo.com/equipment_mfg/Magnavox~Phillips_2.html
http://www.scribd.com/document_downloads/direct/3585482?extension=pdf&ft=1273024095&lt=1273027705&uahk=EPuG
http://www.scribd.com/document_downloads/direct/3586219?extension=pdf&ft=1272926383&lt=1272929993&uahk=qkWcsHnrAA9Iih33SWYE
Please find above, is service and training manuls, these should help you sort out your problem simply follow the troubleshooting procedures and you will soon isolate your problem
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
1helpful
37" Sony Plasma won't remain on
Your mainboard is damaged, replace it and that will solve your issue.
MAGNOVOX 37MF33ID/37
might be the remote sensor or the tv needs some new solder
do you know how to do this kind of stuff?
if not then you should take in to a shop or see if they can fix it at your house
otherwise I'll be glad to help!
TV CUTTING OFF
Check this, for how long the TV is on? 30 min., 45min, 1 hour? because maybe you have accidentally programmed the SLEEP control. If so, go to the set up options or menu with the remote control and check the status of the sleep power off time. Or maybe the TV has the otion to power off automaticly set the same way that is the alarm turn on.
1helpful
Television problem
Hi there!
I would start with power supply caps and regulators. However it could really be anywhere on the circuit, Philips TVs are error sensitive so I would recommend a repair technician. Good Luck, Jus004
Philips 37MF321D 37 in. LCD Television Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
