Have a moen tub faucet put in new o-rings and now it wont stay pushed in to turn off this is a older model that just pulls straight out then turns l/r for hot & cold
make sure you turn the stop under the cabinet off use an allen wrench to take the handle off pull the keeper off the old cartridge pull the old cartridge out and make sure you put stem grease on the o-rings before installing the new cartridge or you will cutt the o-rings and ruin your new cartridge. put you keeper back in and reinstall your handle. turn your water valve back on underneath and enjoy.
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
take the handle off and pull the spout off and there should be 2 o rings around the shaft , you will want to put tons of grease on those o rings and that should solve your problem. if it doesnt call moen 1800 buy moen and ask for a new spout o ring kit they should send it out to you for free!
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
