Stoves 720EF Electric Double Oven Logo
Question about Stoves 720EF Electric Double Oven
My stoves oven is burning my kitchen cupboards
My stoves oven is burning my kitchen cupboards the seal was replaced last year what can it be
Posted by penherbert on
Anonymous
  • 250 Answers
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Posted on Feb 27, 2010
  • Anonymous Mar 01, 2010
    What I forgot to add last time was that the front of the cooker surround should be level, if not just in front of the adjacent cupboard doors. This will ensure that if hot air is escaping, it will not play onto the material.
1helpful
The stove is 26 years old. Has been working very well. Now the two heating elements on the left side of the stove and oven are not working. The pilot lights come on. Fuses in good shape and 220 volts...
check the contact points on the rear of the element they burn off after years of use, if the contacts are still good, Look at the element itself for any white marks on the element, if you see any , the element itself has probably burned out and need replacing , to get to the contacts,, depending on the oven, remove the back they should be right in sight , if you do need to replace the fittings on the wire ends, be sure and get heat range connectors
May 29, 2011 • Ovens
Kitchenaid superba oven - during self cleaning the cupboards on either side get hot to the touch inside the cupboard. At one point it melted the paint on the side of the cupboard that butts up to the...
You should really have a gap between the cupboards and the oven which would be stated in the manufacturers instructions (if you still have them) . I presume it is a free standing oven? You could try Homelux insulation board or stove wrap and is sold in B&Q.
May 17, 2011 • Ovens
Replace seal on Stoves 61GDO, model no. 44444557- last digit has rubbed off with age
444445572 Gas double oven - stainless
http://www.espares.co.uk/parts/cookers-and-hobs/stoves/444445572/p/1092/630/0/914923
It has two different seals on that website, but I think It'll be obvious to you which one you'll need.
Mar 05, 2011 • Ovens
1helpful
2answers
We have a 5 ring Lofra oven (all gas) and live in spain and the seal on the oven door has perished - we need to replace it but it seems Lofra UK has gone bust and from reading reports, Italy is not helpful...
There are many types of seals that can be used which are universal and not specific. You must check with the Kitchen appliances spare parts dealer for assistance. Take along the sample of the gasket to get a look alike type.
Also there are many available in shops that sell penumatic tubings specially silicon gaskets. Only the groove need to match with the heat resistance characteristics.
Sep 15, 2010 • Ovens
My eurolec oven is letting the heat out and burning the cupboards
check that the fibre glass is still in place and has not been soacked with water, you can get some fibre glass from your local stores and wrape it just after openning the couvers and puting them back to place
Aug 02, 2010 • Ovens
How to fit new grill elemnt to stove type 720EF?
You have to remove the complete oven from the kitchen cupboard and then take the top and back off to give access to the wiring.
All the information is in the handbook, if you want a copy, then supply an email address, so that I can register it on my shared folder of the BT Digital Vault you for to take a copy.
Steam is shooting up from stovetop when I'm using the oven, along the back, right side. Is there some kind of seal that can be repaired? Or does the stovetop need to be replaced?
this is normal,the stove must have this feature in order to cook properly and keep your food from tasting like last years turkey
Mar 06, 2010 • Ovens
1helpful
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 • Ovens
2helpful
2answers
Stoves 900GDO Bottom oven door seal
You will probably have to replace the oven door hinges.
This should solve the problem
Top Stoves Ovens Experts
Marvin
Marvin
Narseman
Are you a Stoves Oven Expert? Answer questions, earn points and help others
