My BB 9700 still shows 2 voice messages on screen even though I deleted all my voice messages. I call the voicemail number and there are no more messages in the inbox. How can I remove the voice messages being displayed?
The "10B1" message on your Panasonic KX-TGD390C phone may indicate that your voicemail box is still full, even if you've deleted all the messages. This could be due to some saved or undeleted messages in a different folder or some other issue with your voicemail settings. To clear your mailbox and resolve this issue, you can try the following steps:
Access your voicemail box: Dial your voicemail access number. It's typically a number provided by your phone service provider, such as "123" or "555."
Follow the voice prompts: Once you're in your voicemail system, listen to the voice prompts carefully. There should be an option to manage your messages or change your mailbox settings.
Delete all messages: Even if you've already deleted messages from your phone, there may be some messages still stored in your voicemail box. Use the voicemail system's options to delete all messages.
Check saved messages: Some voicemail systems have a separate folder for saved messages. Make sure to check this folder and delete any saved messages if they exist.
Change mailbox settings: If you cannot find any messages in your voicemail box and it's still showing as full, you may need to access your mailbox settings and reset or reconfigure them. Look for options related to mailbox size, message retention, or other similar settings. You might need to contact your service provider for assistance if you can't find these settings.
Reboot your phone: After you've taken the above steps, it's a good idea to power cycle or reboot your Panasonic phone. This can sometimes help refresh its connection to the voicemail system.
Contact your service provider: If you're still experiencing issues after trying these steps, it's a good idea to contact your phone service provider's customer support for assistance. They can help you troubleshoot and resolve any voicemail-related problems.
Remember that the specific steps and options may vary depending on your phone service provider and the voicemail system they use. It's essential to follow the prompts and options provided by your voicemail system when you access it through your voicemail access number.
Delete voice mail by going through the keypad on your cell phone. The actual procedure depends on the kind of cell phone that you own. For example, on the Nokia 1100, hold down the "1" key while you are on standby. Tracfone connects you to your voicemail, where you can follow spoken menu instructions to listen to your voicemail. After you hear the voice message, you're asked if you want to delete your recordings.
This is not recommended, because connecting in this way uses up your minutes even if you just want to listen to them.
Use your landline phone to delete messages if you want to avoid using your Tracfone minutes. Turn off your cell phone so it doesn't ring and then call your cell phone number from a landline.
Press the "*" (star) key as soon as you hear your voice mail greeting. Then enter your password number and press the "#" (pound) key.
Listen to the instructions for accessing your voice mail, which can vary slightly depending on the phone you have. You are told the number of new and old messages you have, how to listen to them and how to store or delete them. Press the number for listening to the message to hear it, and then the number for deleting.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Next, access your voice mail messages by tapping the
"Voicemail" icon.
Look at your list of current voice messages. If you have any
messages that are eligible for recovery, you'll see an item at the very
bottom called "Deleted Messages". Tap on this to access a list of your
deleted messages.
You should now see a list of deleted voice messages. If you
see the message that you want to recover, tap on it and choose
"Undelete".
5
Your voice message will now be sent back to the main list of
current voice mail messages.
6
Repeat steps 1-5 for "each" message you wish to recover. This
may take time!
for sending text messages :
1. call to your network operator customer care 2. request the message center number... 3.note it down 4. go to message settings>message center number 5. insert the number which is noted by you and save it
this solves your messaging problem ... Good luck
