Question about Teac PD-D2410 5-Disc CD Changer
Cds skip when playing in 5 disc cd changer, purchased lens cleaner it wouldn't run in player (even though the salesperson assured me it would!)
Posted by jamclub on
steve burke
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 25 Answers
Lens cleaner does not work use meyl spirits
Posted on Feb 28, 2010
Won't play, just keeps skipping discs
Good morning Lori.
My troubleshooting thoughts run something like this:
  1. It sounds like it's skipping on every CD.
  2. This is (according to the manual Denon DCM 390 Operating Instructions Manual Troubleshooting a cauousel-type system, so it has a tray that you manually place CDs into, rather than a cassette that you put all the CDs into and then insert into the player.
  3. Most of the manual Troubleshooting section puts the blame for discs not playing upon dirty or damaged discs - you're told to re-load it, clean the disc, try another disc.
  4. If this is just one set of discs, then it's worth it to pull out at least a couple and try other discs that are clean, don't have scratches, and, hopefully, that you know work on another player. If they work, then, kudos to the manual, the discs may need cleaning or replacement.
  5. If you're playing home-burned CDs, you may need to finalize them for play. Computer CD burners can often give you a lot more leeway in what they're willing to play, since there is a much more sophisticated bunch of code running the burner that will have some expectation that in-process discs might end up there.
  6. Last, but, IMO, most likely - steady skipping on every CD can mean that the CD laser lens is dirty. Over time, dust on CDs or from the air drawn through the chassis can build up on the lens, which has a fairly small gap from lens to Disc surface. In something like a DiscMan or other portable CD player, the lens is usually pretty obvious and can be blown off with some canned air or brushed with a micro-fiber camera lens cleaning brush. In this case, it's what I suspect is the problem. Depending on what gear you might have, or how much you'd want to spend on it, what I'd suggest to try fixing this possibility would be :
    1. Use a commercial CD Lens cleaner. They'll likely run 6 to 10 dollars. A list here Amazon com cd lens cleaner Electronics has lots of possibilities. You'll want one of the ones that looks like a CD with a small brush attached to the bottom, possibly some fluid. You'll put it in the player, hit play, it'll at least attempt to play for like 5 to 30 seconds, and end. The brush will be spun past the lens multiple times, removing dust / gunk buildup.
    2. Use canned air. I'm talking commercial stuff expressly meant for cleaning computers and other gear that will suffer from a blast of oil-laden air from a garage air-tool compressor. Examples here Amazon com canned air Electronics
    3. Open the system up. I can't give too much guidance other than I did it years ago on my system - make sure it's unplugged before starting. Remove screws attaching black cover to chassis, and you may be able to get in with a brush to clean the lens. Don't go this direction unless you're confident of your DIY skills.
    4. In any case, try to stick with dry cleaning methods like the cleaner disc or canned air. If you do anything with direct contact, stick to clean microfiber cloth or brushes, and be gentle - no scrubbing motions. It's a tiny lens, and a scratch or mis-alignment from forceful handling will be the end of it. If a liquid must be involved and isn't part of a commercial kit, nothing but distilled water. Many, if not most, of the CD lenses are molded plastic, and glass cleaners, likely as not, will attack the lens surface and roughen or fog it.
  7. Last note - the reviews on Amazon for this unit are not kind. It sounds like the skipping and failure to play is not uncommon with this particular Denon model. If the unit is still under warranty, I'd grab the opportunity to have someone fix it for real and deal with any faulty mechanisms. If not, you have little to lose with the above, but the reviews suggest that replacing with the same model might not be the best idea.
Good Luck, and Happy Holidays
D
Dec 09, 2015 | Denon Home Audio Dcm-290p 5-disc Auto Cd...
Cdp-ce315 skips in songs
My answer here only concerns if you're trying to play burned audio CDs. Burn your audio CDs at the lowest speed (1). Try the JVC/Taiyo Yuden brand.
Nov 09, 2011 | Sony CDP-CE315 5-Disc CD Changer
We cannot use this because the CD's all skip. We found out that there aren't replacements to buy, we tried at Best Buy. we really miss being able to play CD's. Can you help.
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it skip.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Take care.
Feb 03, 2011 | Technics SL-PD687 5-Disc CD Changer
The music is skipping a lot on all discs played on the device
are there scratches on the disks if so i recomend replacement but the lens might be dirty if so you can go to a local walmart and purchase a cd/dvd cleaner and i have provided a link
 http://www.walmart.com/ip/Innovera-CD-DVD-Laser-Lens-Cleaner/14915544
Jan 02, 2011 | Sony CDP-CX400 400-Disc CD Changer
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
CDs skip
Hello
Ok, it sound to me that the laser lens which actually reads the cd's has some dirt particles on it.
There is a very cheap method of solving this problem.
Just go to any cd shop and buy yourself a decent laser lens cleaner disc, follow the instructions and you should be set.
Kind regards
Andrea
Dec 13, 2009 | Technics SL-PD6 5-Disc CD Changer
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Discs are skipping in my changer
cds skip irrespective of their positions as the reading lens is the same for all.
you can do the following
1)this seems to be a SERVICING problem with dust playing the spoilsport.
OR
2)buy a new disc (scratchless) , play it in all positions and com pare.
if it skips in all positions, call an electronic engineer who will replace /repair the delay circuit.
Apr 15, 2008 | Alpine CHA-S624 6-Disc CD Changer
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
Lens Knocking Against The CD - All CDs skip or diginoise then fail.
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
Jul 29, 2007 | Sony CDP-CX400 400-Disc CD Changer
Teac PD-D2410 5-Disc CD Changer Logo
Top Teac Audio Players & Recorders Experts
efs_perpends
efs_perpends
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
