AOC CT720G 17" CRT Monitor Logo
Posted on Feb 20, 2010
AOC CT720G, 17 in. (Black, Silver)CRT Conventional Monitor menu pops up all the time with out even touching the menue button
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Dec 22, 2007
SOURCE: monitor menu problems
Hai Ejor,
You need to replace the front panel menu buttons,
Regards
Aby
viziks
Samir Shah
  • 220 Answers
  • Posted on Jul 26, 2008
SOURCE: AOC 17" Flat CRT Monitor
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Samir
Anonymous
  • Posted on Jan 26, 2009
SOURCE: AOC MONITOR Conventional
just press all the control buttons one at time. It works for me.
Fabio
  • 400 Answers
  • Posted on Jul 24, 2009
SOURCE: My Monitor AOC CRT Model F1770 is always adjusting
Try to unplug the power cable from the mains for about 10 minutes then replug and try again.
Make sure all cables are well connected.
Try to test it on another computer if possible.
If that doesnt help then it sounds like a hardware problem with the monitor and you wont be able to repair it your self.
Anonymous
  • Posted on Jul 27, 2009
SOURCE: the menu is always pop up
so what is the best solution guys?
AOC CT720G (Black, Silver) 17" CRT Monitor driver
The monitor probably doesn't require any special driver. There are drivers for your motherboard video chip, or if you have a graphics card. If you need to make adjustments to the monitor, the manual is here... http://www.manualslib.com/manual/8152/Aoc-Ct700g.html
Without knowing i have changed screen size and boarders. now i cannot fix it.
go to the menu through the buttons on your monitor and start navigating through it so that u get a submenu giving u options to edit the screen size
1helpful
4answers
The menu is always pop up
Power blink
Horizontal output transistor is shorted or flyback problem
2answers
Samir
Problem in my aoc monitor
pls replace control button 4no
Aoc 17 inch silver black monitor problem
main regulator capacitor for the hot side of the power supply may need replacement, usually value is 220uf to 400uf 400 volts..
Monitor Menu
Check if the Menu button is not stuck or malfunctioning.
2answers
Menu display
hi, you can change the push bottom of the control user, i am repair various for the same problem
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
