If the model number is correct, the self-cleaning instructions are as follows:
1. Make sure oven door is closed and press "CLEAN".
2. "REMOVE RACKS" should be displayed. Remove all oven racks to avoid damaging them.
3. Select "CONTINUE" using the Quickset pads on either side of the control panel.
4. Set LIGHT soil level by entering "200" using the number pads for 2 hours cleaning. Select MEDIUM for 3 hours. Select HEAVY for 4 hours.
5. "CLEAN", "TIME", "LOCKED" and the cleaning time countdown will be displayed while the oven is cleaning.
6. "OVEN COOLING" will appear when the cleaning time is complete, but the oven door will remain locked until it is safe to open. (approx. one hour after cleaning cycle ends).
These instructions are almost verbatim on page 23 of your owner/operator's manual. If you no longer have a manual, you can go to managemylife.com and enter your model number under the "Manuals" link. Your owner and installation manuals are listed in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, or if your model number is different, please post back and let me know. I hope this helps you.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
heatman101
heatman101
