Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Inducer motor for a carrier weather maker 8000
Posted by jec271954 on
Anonymous
    Champion:
  • 207 Answers
What about it i need more info
Posted on Feb 26, 2010
Carrier weathermaker 8000
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
Check to see if anything has built nest in the inducer motor assembly...or a bird worked its way into it.
Dec 10, 2013 | Heating & Cooling
Will not ignite. LED Code 31
Could well be the inducer motor Google carrier 31fault code there are 3 video's on this on u tube
Jan 15, 2018 | Carrier Weathermaker 8000 Gas Furnace 125k...
Hi, I have no power coming to the weather maker...
double check the breakers. Turn ALL THE WAY OFF, then ON.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 22, 2017 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Carrier Weathermaker 8000 VS furnace that intermittently has frozen up (the inducer blower stops spinning). Do I need to replace the blower or is there something else that can be done? What is the...
If you can get to the shaft of the motor, oil it using electric motor oil. If the motor spins freely, you just may need to replace the start capacitor, however if it is binding; you will need to replace the inducer as an assembly.
Jan 18, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker 8000 furnance flashing code 31 blower comes on for 90 sec .. then shuts off .. then other fan goes on.. don't see any flames or lighting goin on can you help?
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than five minutes,
inducer shuts off for 15 minutes before retry. Check for: - Excessive wind
- Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used) - Restricted vent
If it opens during blower on-delay period, blower will come on for the selected blower
off-delay.
33 LIMIT CIRCUIT FAULT - Indicates
Nov 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Gas not coming on Carrier Weather Maker 8000
either the gas valve is not opening or your not getting gas to the furnace.  also the gas valve won't open unless the draft motor comes on.  if the ignitor is trying to light, but there's no gas, it might be a bad gas valve. i would call your closest NATE certified contractor
Nov 12, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
491 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
