Question about Vacuums
Carpet function won't work.
When engaging the carpet function, the warning light comes on and it sounds like something's stuck in small bottom hose into brush area. Brush bar does not rotate. Nothing is stuck in the primary hose and hand tools work just fine with no warning light. How do I get the small hose out to check for a clog?
Posted by dutchman0 on
A Miller
  • 8,404 Answers
You are going to have to get a screw driver and remove the bottom plate and the hoses. You are correct, there is a clog. You might be able to clear if you have a shop vac. Be prepared to remove all the connections in the dirt path to remove the hair ball.
Thanks for your interest in FixYa.com
Posted on Feb 20, 2010
Why wont my carpet brush work, and why wont vacuum shut off?
I think you have two different issues, the power switch. Many of these are foot operated and have hard lives. Try to spray a bit of WD40 on the shaft of the switch and it may help but you could well be looking at replacement. As for the carpet brush, use a multimeter in the 200VAC setting and check voltage where the power goes to the wand and carpet brush. If there is 120 when on then move on to the attachment and measure there. Look for reset buttons (Not all have those - they disengage if it gets stuck - like a large length of twine, etc...) Next if not working, measure resistance going at the brush with your meter. It should show 100-200 ohms. If not the motor is dead. While at it, check continuity on the wire feeding the brush.
Mar 07, 2018 | Vacuums
I have a simplicity 7350 vacuum. The belt and roller have recently been replaced. It runs fine on floor mode and has no problems with suction. When I put the vacuum in carpet mode, I do not hear the motor...
the motor spins around a steel shaft that sticks out on one end, and the belt is driven by that shaft, belts are easily damaged and broken, meaning roller wont spin. Often a burning smell of rubber is noticed after motor shaft spins on stuck belt. cause is always hair./string/something at the three contact points. motor shaft and belt, roller and vacuum body become clogged. become familiar with taking cover off roller/belt, and cleaning Checking moving parts roller/belt come out easily and simple to clean...keep spare belts.
Mar 10, 2014 | Vacuums
I have an electrolux discovery II vacuum cleaner and the floor function works, but when I try to switch over to carpet mode, it doesn't seem to engage.
There is a red reset button on the back of the machine. When it trips, the brush won't engage. Press the reset button and then try your machine again.
Apr 07, 2011 | Electrolux Vacuums
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
THe vacuum won't divert from hose to carpet
Turn the vacuum off, return the handle to upright locked position.
Then securely fit hose into the hose holder.
Then depress lever and engage handle into non-locked position, and turn on vacuum on "carpet"
There will always be some airflow through the hose, but when the hose is parked it creates more airflow to the carpet head
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
With the hose on I have suction, with the carpet head not much
it looks to me u have something stuck in ur hose or in the carpet head....if u can loosen the hose use a broom handle and push it true....u may be suprized what u will find......good luck
Mar 28, 2009 | Kirby G5 Bagged Upright Vacuum
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Jun 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
