Bit confused by your question as you cant download a computer!! If your after the software for your Aladin try ebay or order it from any Scuba store that stocks aladin pro computers. Hope that helps.
Unfortunately no it is not. Although it may be possible to do this yourself what the service centre will do is pressure test the unit after battery change to ensure that the computer is still accurate at depth and water tight of course. Hope that helps
Battery life is completely dependant on how often you use the computer to dive with. Batteries should generally be changed every two years regardless of use. An authorised dealer will also use the best recommended battery for the unit and not use cheap imported batteries. Hope that helps
Yes you will need to send/take it to your nearest authorised service centre. Try asking your nearest Dive centre or scuba store. They will be able to direct you to the best place. Hope that helps
Hello replacement wrist bands are available from any Uwatec stockist (They may have to order it for you) Try speaking to your nearest Scuba store. Hope that helps.
MITSUBISHI DAIYA ... performance, read and follow this User's Manual carefully before using your air condi- ... Operation and indication section for remote control . ....Symbols which appear frequently in the text have the following meaning:.
Mitsubishi ElectricUser Manuals/instruction booklets (including remote control instructions) forMitsubishi Electric Air Conditioners. ... Air Conditioning Downloads · Residential Air ...Need to know how to operate a Mitsubishi Electric air conditioning system?
Ive not personally heard of this make, generally it is fairly difficult if not impossible to find manuals for older computers, if you have the model number you could try a Google search. Hope that helps
