Question about White Sewing Sewing Machines
After depressing the pedal, my White 1077 Jeans Machine will not raise and lower the needle, though I hear something spinning inside. I can hand crank it, but it has a lot of resistance. This problem occurred after using it for hours sewing with free motion.
Posted by christineann on
paj42
    Genius:
  • 1,116 Answers
If this model has an engage/disengage feature for the feed dogs, did you engage them before regular sewing?
After 8 - 10 hours of sewing, the needle should be replaced with a new one.
Are you stitching a heavy fabric? A machine will sometimes stall if the fabric is too thick.
Posted on Feb 20, 2010
What is a never used white jeans machine model 1077 worth?
Umm, an unused old sewing machine sounds like it should be worth a lot, however, in retrospect, machines need to be used and maintained regularly. Most likely the machine needs a thorough service as the oil has probably dried out over time and has/will seize the machine.
Vintage White Zig Zag Sewing Machine Model 1077 Cover Jeans Machine eBay
Jun 19, 2018 | Sewing Machines
The needle moves up and down and the presser foot is lowered (and attached properly) but the fabric is not being pulled through.
Yes, there definitely could be something wrong, but there are some things you should check. Most machines are capable of raising and lowering the feed dogs; yours might be fully or partially lowered, so that while it moves, it's not far enough up to the surface to move the fabric. Using the lever or dial, LOWER it all the way, then RAISE it all the way, but you're not finished. It will still not raise until you turn the hand wheel TOWARDS you (ALWAYS towards you on every machine) at least one and possibly two revolutions. You'll then SEE and most likely HEAR it click up. I know someone who got a steal on a Brother marked defective because the feed dogs wouldn't raise, so she brought it home, turned the hand wheel two revolutions, and viola! The feed dogs raised!
Dec 03, 2013 | Singer 5050 Mechanical Sewing Machine
The lower thread does not bring up , so that the uper thread does not come in contact with the lower thread .I hear unusaul noise while sewing.All these happend when I tried to sew a jeans .i used a thread...
As a general rule, domestic machines don't like buttonhole twist, that heavy yellow thread you see on the RTW jeans. Sometimes you can put it through the bobbin but use a regular weight thread on top but this means sewing upside down as you'll want the yellow on top. And lots of machines dont like different weight thread top and bottom so it just makes for awful stitching anyway.
Best solution to top stitch jeans is use a regular weight thread, large size jeans needle but thread up two spools of thread on the top with both threads going through the same needle eye. It still may not solve the problem though.
To your machine, firstly change the needle as it may be bent. Then unthread the machine and manually turn the flywheel through a stitch cycle and listen carefully, if you still hear a noise as the needle touches the rotary hook, you've knocked the timing out. Service man visit time.
Probably if you check the manual, it will say 50 weight thread, and you'll need to stick with that in the future.
Those big industrial sewing machines that they top sew jeans on are very different to a domestic SM, many make a chain stitch or fell the jeans seams and are very heavy duty.
Jun 05, 2011 | Toyota STF17 Sewing Machine
I have an old Pfaff 90 Sewing Machine, largely mechanical. However, I seem to have run into an electrical problem. I was just sewing and pressed down the foot pedal and when I raised my foot, the needle...
I am pretty sure it is the foot pedal. It will need to be repaired. You might want to blow air inside to get rid of dust. The bottom usually slides to the rear. You can blow out all of the parts. You may want to slightly tap your foot pedal on the floor. Remove the thread first though. You may find that it will stop when you do this. Anyway, repair or replace.
Mar 24, 2017 | PfaFF Sewing Machines
The thread bunches up underneath the fabric and then the machine stops after about 3/4 " of running. IM sure there is a simple solution, but I dont know what.
Refer to the maintenance section of your manual for cleaning the machine.
Always thread a sewing machine with the presser foot up.
Check the needle to be sure the flat side of the needle shaft faces the back of the machine.
Check the bobbin to be sure the thread is feeding in the correct direction and though the proper guides.
Using the handwheel, lower the threaded needle, holding onto the the end of the thread and then raise to pull up the bobbin thread.
Take both threads under the presser foot and to the back of the sewing machine.
Place the fabric under the presser foot and while holding onto both threads, lower the needle into the fabric by turning the handwheel by hand and create one stitch.
Let go of the threads and press on the power pedal.
If this does not resolve the issue, the machine may need the timing adjusted and this needs to be done in a shop by an authorized Singer tech.
If the machine is new, the warranty may cover the adjustment.
Apr 02, 2010 | Singer 2250 Tradition
Hd-110 can't pull up the bobbin thread
If the needle will not catch the bobbin thread, try replacing the needle and make sure the flat side of the needle shaft is facing the back of the machine.
Lower and raise the threaded needle, while holding onto the end of the thread. This will pull up the bobbin thread.
Take both thread ends under the presser foot and to the back of the sewing machine.
Hand Walk the needle a couple of stitches before using the power pedal.
Mar 19, 2010 | Singer HD-110 Mechanical Sewing Machine
It seems that the needle is not coordinated with the bobbin because there is no stitch.
It is possible that the needle is not installed correctly - this is usually with the flat side facing the back of the machine.
Always thread the top thread with the presser foot up.
Hold onto the thread tail at the needle and (by hand and not with the power pedal) turn the handwheel to lower and raise the bobbin thread.
Take both thread tails under the presser foot and toward the back of the machine before you begin to sew.
Feb 20, 2010 | Necchi 4575 Mechanical Sewing Machine
Singer 8280 bent needle, now machine wont work
Depends what it would cost for service. Most standard service would cost at least $50-100. You can purchase a replacement machine for ~$100.
Amazon com Singer Sewing Machine Model 8280
Jan 01, 2018 | Singer 8280 Mechanical Sewing Machine
Hand wheel will not turn
A FRIEND GAVE ME A SUPERLOCK 2000 WITH THE SAME PROBLEM. THE HANDWHEEL WAS HARD TO TURN AND MACHINE WONT RUN WHEN PLUGGED IN. I OPENED THE SIDE COVER WHERE HANDWHEEL IS LOCATED. FOUND THE BELT WAS DRIVEN OFF THE MOTOR. PUT ON THE BELT ON THE MOTOR, OILED THE MOVING PARTS.
WOKRING GREAT NOW.
Apr 30, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Sewing Machines Logo
179 people viewed this question
Top White Sewing Sewing Machines Experts
Colin Stickland
Colin Stickland
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
