Adjusting 2007 aveo rear brakes
do not attempt any adjustments. replace the front brakes when they need it. if you try to adjust the proportioning valve you will lock up your back brakes and risk loosing control of your vehicle. you risk ruining the ABS system in your car which will cost you far far more to replace than a cheap set of brake pads. the front brakes do most of the stoping, that is why they wear out much faster than the back brakes. it is VERY IMPORTANT that you DO NOT attempt to adjust your brake proportioning valve.
