I have a Kenwood KAC-X812D amp and a alpine SWR- 1242D Subwoofer in a sealed box. What is the best setting i should do for this amp. HEADUNIT KDC- X592
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Ported and tuned to around 37-40 hertz. After all displacement the box should be in the 2.2 cubic foot for sub and you will be very impressed. Build it yourself for optimum sound and output.
i have a Kenwood KAC-X812D amp and a alpine SWR- 1242D Subwoofer in a sealed box. What is the best setting i should do for this amp. HEADUNIT KDC- X592
Kevlar reinforced pulp cone with Santoprene™ rubber surround
cast aluminum frame with perimeter venting
frequency response: 25-500 Hz
power handling: 200-500 watts RMS (250 watts per coil)
peak power: 1,500 watts
sensitivity: 85 dB
top-mount depth: 7-5/8"
sealed box volume: 0.57-1.0 cu. ft.
ported box volume: 0.75-2.0 cu. ft.
For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
