Question about Refrigerators
I have a Westinghouse WSE6100SA side by side fridge freezer. It is set at factory defaults of -18 for freezer and 3 for fridge. The fridge compartment has started freezng all the food. I have tried adjusting setings and also turning fridge on and off to reset but nothing works it keeps freezing the food. What could the probelm be?
The thermostat has broken down and needs to be replaced,, normaly when they brake down they just stay in the closed poshion so the fridge freezes up get a new one fitted and all will be well
Posted on Feb 19, 2010
Testimonial: "Thanks for you fast response, very helpful. I thought this may be the problem but wasnt sure. Are the thermostats easy to replace? Could I DIY, How?"
miket 756
you could fit a new thermostat yourself but its not easy to do and they can be broken very easly,, i would fine out how much it would cost to have it fitted first,, if its going to cost you an arm and a leg then have a go yourself,, but if you busted it then its not getting any cheaper is it? you should also get a warranty for any work done, so if it did brake down again soon its coverd
Feb 15, 2017 | Refrigerators
May 07, 2015 | Westinghouse Refrigerators
May 04, 2012 | Televison & Video
Feb 24, 2010 | Westinghouse Refrigerators
Feb 19, 2010 | Westinghouse Refrigerators
Sep 04, 2009 | Refrigerators
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Nov 25, 2008 | Refrigerators
Jan 15, 2021 | Refrigerators
1,143 people viewed this question
