Motorola Mobility RAZR V3 Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant turn key pad noise off ...Is this possible?
Anonymous
Level 2:
New Friend:
  • Expert 124 Answers
  • Posted on Feb 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
124
Questions
0
Helped
25675
Points
343
I also had the razr and couldn't stand the noise. Heres what you'll do to solve it:
1) Menu
2) Settings
3) Audio
4) (ringstyle) Detail
5) Change the key volume for each that would actually ring.
Hope this helps,
Joe
I have an 02 Dodge Ram 1500 ,2wd.Whenever I turn left,my truck makes a squealing noise,like a worn brake pad.Checked all brakes,ok.Cant figure out what or where noise is coming from
You could easily have a front wheel bearing going bad. They tend to get louder when turning. The squeal can be from the bearing itself, or possible from the brake rotor rubbing on the brake stone guard behind the rotor when turning. That rubbing won't occur unless there is excessive play in the wheel bearing or if the guard is bent.
Dist noise
Got squeaky brakes, hey. Or is it chirping? Squeaky brakes are fairly common on vehicles that have all four wheels that are disk. Now, chirping is a different story, it could mean that you will need new disk pads and possible have the rotators turns and if the can't turn the rotators then they need to be replaced. Squeaky brakes, glazing on the pads, pad dust, little rocks, brake spiders, loose adjust spring, and many other possibilities. GB...stewbison
3helpful
2answers
Cant unlock key pad on a nokia c3. was working
If you forgot the security password, then you need to master reset the phone. We recommend you to contact your service provider to get the master reset code.
How do you turn off the keypad noise i have a silver samsung flip phone - not a new model
Hello
To turn of the key pad noise, Go to MENU< SETTING< TONE SETTING< KEYPAD TONE.
When you get to key pad tone, you turn it off.
Hope this solve your problem. If not do not hesitate to leave comment.
Regards
I cannot turn off the Fix key on a TI-15 calculator. Help!
Is it possible that the key pad is dirty? You may have to take the calculator apart and clean the key pad area. Don't do it unless you are fairly handy. Good luck!
1helpful
My phone backlight turns off its own every time I asnwer the call, its totally annoying because i cant see the second calls, cant put it hold, cant chek the time....etc Especially can't make the selection...
The phone is NOT turning off... it just returns to the home screen. Press the phone key, which is next to your home key and the phone will return to the key pad.
Cant get mouse keypad to work my husband pressed something and now it will not work
some laptops have buttons to turn the pad off sometimes they are right on the edge of the pad or in the F keys. usually have to hold the FN button then a certain F key.
1helpful
2answers
I hear a clicking noice from rear passenger side panel inside my 2003 Ford Expedition Eddie Baurer when I turn key on in ignition.
its your rear a/c actuator door in the rear RH side panel. The door is damaged or binding, replace it with a new one. To access this, you must remove the panel or top cover. hopefully this helps
Car wont start
could possibly be a flat battery possible could be the starter motor also when you unlock the car with the key the immobilizer should of disarm
Key stuck in ignition
Be sure its all the way in park or try neutral.Its possible that security system does not recognize the key. Is security light flashing or on steady? Shut all doors and windows,trunk,hood, turn off all accessory's,roll down drivers window, turn key off and remove for at least 1 minute, insert key into ignition, try to start leaving key to run position for 20 minutes, turn key to off,wait 15 seconds, try to start again leaving key to run, wait 20 minutes, turn key off,wait 15 seconds, try to start, again leaving key to run, wait 20 minutes, turn key off, wait 15 seconds, try to start. This should relearn key code. It may relearn after 1 learn cycle and start if system is ok. Hope this helps and that the weather is dry and warm for this procedure! This is not always a fix, but works most of the time.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
