Hola santipatag!
I have found two schematic diagrams that are very close to your radio. one is a lessor model and the next is one that is a bit fancier than yours. I would think the output stages would be about the same with maybe a SWR sense function.
Please email me and I will return the diagrams directly to you..... Here is my email
[email protected]
Hasta Luego mi amigo! Rod KB8DNS
Wharfedale pro bx1360sd
I have had problems with this stereo mixer amplifier which had the symptoms of no sound output from either channel .
I opened up the unit and discovered that the amplifier was correctly amplifying my input signal up to a relay which switches the output through to the speakers .
This relay did not activate at all.
When the power switch is turned ON you should hear a click approximately 2 seconds later , if no click then there is a problem with the circuitry associated with this relay .
I traced out all the connections associated with this relay and made a circuit diagram .
The relay is a 24v relay and I will explain the way that I can see that this section of the amplifier works.
It has been designed to ;
This it needed because otherwise there is a current surge and sparks from the relay turning on immediately.
Q804 turns On Q805 which turns On Q806 to activate the relay .
Voltages on transistors
Q802 and Q803 2sc1815
Base 0V Collector 12.9V Emitter 0V
Q804 2sa1015
Base 12.9V Collector 0V Emitter 15.1V
Q805 2sc1815 (driver for Q806)
Base 0V Collector 7.2V Emitter 0V
Q806 2sc1815
Base 0V at Turn ON then after 2 secs increases to 0.7V
Collector 2.8V ( transistor is activated as a switch Turned Fully ON ( saturated) to turn on the Load which is the relay .
Emitter 0V
I have replaced the following transistors to fix my amplifier q805 2sc1815 and q806 2sc1815 .If you are going to use a different type of transistor it may not work and also the lead connections of a 2sc1815 for the collector and emitter are different to those such as on a 2n2222( transposed).
This CB radio is an used piece of equipment...I worked on it for one hour before I discovered two output transistor were not RF type, the original were missing
I made a phone call to the owner to get from him an answer to this situation.
Self repair or a helpy friend !!!!!
I`m stuck! please I need information about the final stage CB UNIDEN MODEL PRO 501 XL
I´m making a home made schematic of this old CB radio to give this a solution
Any help will be appreciated
Thank You
Santiago Ansin
AC4406 USA
Puerto Deseado-Santa Cruz
Patagonia Argentina
Please give some history on this radio, like is it used? did someone work on it?
