Question about The Learning Company PrintMaster Gold 15 for PC
SOURCE: I bought a new computer with Windows 7. Is
This should answer your question
I understand that you are inquiring if Printmaster 18 is compatible with Windows 7. Our developers have tested every aspect of Printmaster 18 to see if it will function properly on Windows 7. It has passed all tests except one, which is the Save As PDF feature. Our developers just became aware of this and are working on a resolution to make it work on the Windows 7 operating system. We apologize for any inconvenience this has caused, but we can assure you that we will provide a fix for this as soon as possible.
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
Posted on Jan 10, 2010
SOURCE: I have Printmaster 7.0 but it is not compatible
The upgrade path is to Printmaster Platinum 18.1 or Printmaster Platinum 2.0. I'm not sure which is better for you but both are $39.99 from http://www.printmaster.com/ .
The installers for Windows have changed over the years. Your alternatives would be to use a dual boot or virtual computer with XP installed. Win7 Pro and Ultimate allow you to run XP mode free after downloading two programs from Microsoft. All the other options require a licensed (paid) version of XP.
The compatibility mode is available but I'm not sure it will work in this case. You would need to right click on the installer and choose Properties. Then go to the Compatibility tab and chose an older version of Windows (Win98 may be a better choice than XP). Then right click on the installer again and chose Run as Administrator. Then you will need to do the same thing with the actual program.
I hope this helps.
Posted on Aug 25, 2010
SOURCE: Printmaster and Windows Vista
been running printmaster platinum 8.0 for many years on several different computers . have had it installed and running on my HPPavilion slimline for two years now . problem is that i cant get it too print anything new that i create it will print out older stuff that i have created but nothing new . have checked drivers on print they are all up to snuff , and have uninstalled and reinstalled both the printer and the printmaster program but still cant get it too print anything new that i create . it does print everything else in the PM program. and otherwheres on my computer
Posted on Sep 15, 2010
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Posted on Oct 24, 2010
SOURCE: I could not install PrintMaster Publishing Suite
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
Posted on Dec 06, 2010
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
Mar 19, 2011 | Encore PrintMaster 17 Gold for PC
Feb 25, 2011 | Mindscape PrintMaster Premier 7.0
Feb 20, 2011 | Computers & Internet
Dec 19, 2010 | Broderbund PrintMaster Gold Version 18
Dec 12, 2010 | Broderbund PrintMaster Platinum 15 Full...
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
Jun 20, 2010 | The Learning Company PrintMaster...
Jan 10, 2010 | Broderbund PrintMaster Platinum Version 18
Apr 17, 2017 | The Learning Company PrintMaster Gold 15...
Oct 08, 2010 | The Learning Company PrintMaster Gold 15...
726 people viewed this question
