Car Audio & Video Logo
Posted on Feb 19, 2010
Put in radio code on Nissan primastar van
The screen does not display the radio for some reason and is not broke as the clock works
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Feb 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
Helped
5262
Points
29
U need some radio expert for that,,, that happend to my pioneer radio...it was just a led light conection in the detachable face but the radio worked fine..
1helpful
Can anyone with Renault radio code calculator software supply code for U414 SECURITY
Available here 24/7
http://renault-radio-codes.blogspot.co.uk/
1helpful
Primastar radio code
Need to call the dealer and give them your vin #
Need the radio code for my CD player in my nissan primastar/renault trafic van.
you need to get the barcode on the right side of your radio and tell me the last four digits e.g. A123
Need a code for my radio nissan primastar
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Nissan service centre and get them to enter this code for you.
2answers
2002 nissan sentra stereo light won't turn off
Im not familiar with the Sentra radio, but on two car radios that I have, there is a display button that switches between frequency and clock when the radio is on. If you push this button with the radio off the light goes out. Hope this helps.
Chris.
2answers
What is the radio pin for a nissan primastar van ?
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Nissan servicecentre and get them to enter this code for you.
How do i reset my radio on a nissan primastar van
I have a nissan primastar and no volume on the radio ..its it faulty or do i need to put in the code ?
10helpful
3answers
HI, my renault clio radio and clock display are dead
Hi All, the very same thing happened to me. Cold weather broke my radio and the display screen stayed on with the time and temperature but the radio wouldn't work. I rang Renault & they said I need to come in an get a new radio but I put it off. In the end the problem started affecting my battery and the car wouldn't start. But then when I jump started it, it also started the radio again perfectly. Problem solved!
Hope this helps. Good luck!
2000 Nissan Pathfinder No radio Display
I heard from someone else that it is a circuit board. Cheaper to replace than repair.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
