Im new to hooking up amps and my friend gave me a alphasonik hck-2050. I was wondering how to hook it up?
First what are u trying to push, second, the amp is 150w rms. that mean constant power, and 250 @ 2 ohms, now you have power, gnd=ground, and remote<- that turns the amp on when you turn on the car, power or the + sign is what gets connected to the battery, then the ground/gnd or - sign is what gets screwed to the metal of the car, then there is the remote this wire gets connected to your radio, or to any accessory fuse, i.e. lighter, radio fuse, or if you have an aftermarket radio, then it gets connected to the blue with white stripe wire, that will be the amp turn on wire.
You will need red wire about 17ft, black wire about 1ft, and 15 to 16 ft of remote wire, or you can just by an amp kit, that will be easier.
now that the amp is done, time to do the speakers;
You have + and - on the amp, and your speakers have the same signs as well, just make sure when you wire the speakers + goes to + and - goes to -. if you need more help call me @ 6314330567
