Hello. Begin by trying a second VHS tape, and then a third. If it still will not work return the TV for one that works.....it is under warranty.
Clcik on the link below to view the owners manual for your JVC DR-MV5S DVD Recorder and scroll down to page 37 and follow the instruction in the chapter "From VHS to DVD"
http://resources.jvc.com/Resources/00/00/94/LPT1032-001B.pdf
Please explain your hook up so that I can tell you whether its correct and what else you have to do to be able to do this.
Sai.
Ok. I think I understood what your problem is. But first those red, yellow, white cables are called RCA component cables. Anyways the problem you are facing may be due to the tapes are sticky. This can happen if you haven't used them for a while. Jusf fast forward your tape and rewind them and see if they play. Let me know if it worked so that we can try something else if it didn't.
Sai.
Ok.. When you connect using an RCA cable you should set the input mode to "Component" on tv. Did you do that too? Also did you try another input like S-video to see if any picture appears?
I am using standard white, yellow, red hookups, and/or blue, green, red type. Sorry I do not know the technical name for them. I am pretty sure they r hooked up correctly. The DVDs play fine. When I put in a VHS tape, all I get is a blank screen on the TV with loud static noise. I cannot hook this up to my cable box, as there is only one cable out coneection...no cable in. I do not need it to broadcast tv signals anyway. I only wish to view and dub my VHS tapes to DVD.
I tried to dub a VHS tape to DVD with my above mentioned status, and all that was recorded was the static noise. I also tried to play the Disney movie Aladdin on VHS and it did not come on the tv screen either, so I know it is not the VHS tapes. I do not wish to invest in another dubbing machine if I do not have to. And I do wish to keep the machine to play my DVDs.
I am hoping that my frustratin is due to a very simple, "duhh, how stupid am I?" error. Any suggestions?
I already tried that.....all that comes out on the DVD is the static noise, no picture.
Did that too...still no picture and only static noise on the VHS setting
