Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I had code AO displayed on my hayward H250IDE. I found the blower motor frozen and burnt. After replacing it I still have the AO code. The blower fan starts running as soon as I turn on the power and after a few seconds the AO code is displayed. The hoses are not pluged and the blower switch on the right checks good. Any help would be great. Also the blower never turns off. I am guessing thats why in burned up.
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Posted on Mar 01, 2010
Testimonial: "Thank you very much for the assit. I did find a kink in the vent safety switch. Thanks again."
May 13, 2014 | Hayward H Series Pool & Spa Heater 400k...
Apr 07, 2014 | Hayward H Series Pool & Spa Heater 400k...
Jan 26, 2014 | Hayward Pool & Spa
Nov 27, 2012 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Dec 30, 2010 | Hayward H Series Pool & Spa Heater 400k...
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
May 19, 2010 | Hayward H-series Electronic Gas Pool...
May 18, 2010 | Hayward H Series Pool & Spa Heater 400k...
Jun 30, 2016 | Hayward H Series Pool & Spa Heater 400k...
1,577 people viewed this question
I did some further troubleshooting and found all the safety switches good. The JQ1aP-B-24v relay on the board at position K1 was testing closed with power off. The contacts were welded together. The new relay is on the way. I beleve the AO code was displayed because the switches were closed before the unit thought they should be, due the stuck relay. Thanks for the help.
I soldered in the new relay on the board and all is well. A new board or $4.00 relay. I think I got lucky.
