Hitachi DZ-HS300A DVD Camcorder Logo
Question about Hitachi DZ-HS300A DVD Camcorder
I live in Brazil. I bought a DZ-HS300A. The PC not recognize the cam. I plug the USB cable and nothing happen.
  • Anonymous Mar 14, 2010
    USB2
    NO
    ALL PORTS
    NO, is Plug And Play
    First Vista, after XP that the OS correct.
    USB2
    NO
    ALL PORTS
Anonymous
    New Friend:
How old is the camera (USB1/USB2)?
Are you behind a USB hub?
Have you tried multiple USB Ports on computer as watchdog may have them timed out?
Did this device require OEM drivers that needed to be installed prior to device installation?
What version OS are you running?
Posted on Feb 19, 2010
When i plug in my usb web cam into my pc, nothing at all happens or pops up. what do i do?
the pc could not recognize your web cam, try to plug out your usb web cam and blow or wipe the usb of your usb webcam. also try to plug it in to other usb port of your pc. if nothing happens, maybe the web cam it is the problem. and just to make sure that the web cam your using is the problem, try other usb web cam to see if its working on your pc. if the other web cam works on your pc, the web cam your using is damage, and if the other webcam is also not working, the usb ports of your computer is the problem.
thank you for choosig fixya. if you have other question regarding to this problem, just post it.
I want to do live streaming using the hitachi camcorder DZ-HS300A. The camcorder will have to be attached to my pc, and recording the presentation at the same time. Is this possible?
Yes, need to purchase a special transfer cable, I use Vivo from Sima. Call your local computer store before going, since it is not that readily availalbe. Got mine at Best Buy. Happy broadcasting. God bless
Not in use
Your USB Port in not updated with the camera port. u have to use memory card reader.
DZ-HS300 DVD/HDD Hybrid Camcorder driver
i need a site that i can down load the installation CD back for free because mine got lost and i can get the videos off of the cam where do i go to fix it i don't want to burn it with the cam i want to edit it on my pc can u help me model # dz-hs300a
I have a sont dcr trv120e cam corder .. when i plug it in pc nothing happens :(
Please install software "Picture Package" CD came with camera. Connect USB cable to camera and other end of cable to PC. Windows XP or Vista will recognize it and install its drivers automatically. If camera is not recognized by Windows, go to camera Menu, enable USB Streaming and check. Hope info will help you.
Regards,
Re: Hitachi DZ-MV550A, NTSC DVD Camcorder
The answer depends on a lot of things. If you plug your cam in and it doesn't make that happy plug and play sound, then it could possibly be your usb port. If your PC recognizes that a USB periphial has been connected but does not install the drivers correctly, then you should make sure that you have the right cam drivers for your operating system. If that has went correctly then there's one more test to see if your pc has recognized the camera. Go to my computer look at all of the drive letters for one that is not there whenever the camera is unpluggedc. If a drive shows up when the cam is plugged in, then it recognized your cam, especially if you can navigate to folders within that are labeled DCIM or RTAV.
Top Hitachi Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
