Question about NordicTrack Exercise & Fitness
Nordictrack EXP 1000 Treadmill Quits after 10 Minutes
I have a Nordictrack EXP 1000 Treadmill (Model # NCTL0999.3) which quits after about 10 minutes of running on it. After a few minutes, it will start again, but has the same problem but only runs for a couple of minutes. I have lubricated and adjusted the walking belt, replaced the motor and drive belt (and adjusted properly), but the same thing happens.
I have a few questions:
1. What is the most likely cause? Is it:
(a) power board?
(b) controller?
(c) walking belt worn or
(d) choke {called that in parts list, but I think it is what I'd normally call a transformer}
2. If I replace the walking belt, under what circumstances would I need to replace the walking board and rollers? How can I tell if they need replacing?
Any help or suggestions you could provide would be very much appreciated.
Thanks,
Posted by coryc999 on
Anonymous
  • 103 Answers
Hello There, Thank you for all the information. It appears as if your walk belt is worn. What is happening is the friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside where the 2 blue wires go) When the belt wears the cloth on the underside becomes flattened out causing too much surface area to contact the walk board, thus the extra friction.
To check your walk board you can loosen the adjusting bolts on the rear and while lifting the walk board look underneath. If there is any wear/white areas then you will need to replace the board as well. You will be able to tell by just rubbing your hand across it and check for any places where the black film may be coming off.
Also the only time you really need to replace any of the rollers is when the bearings go bad or the pulley on the front roller separates. The rollers are about a 1% chance of causing this problem.
Good Luck! and great question, Tim
Posted on Feb 21, 2010
Exp 1000 belt
see the video and proceed according. lube the rollers bearing front+back too.
God bless you
Oct 22, 2013 | Nordic Track NordicTrack Treadmill, A2550
How do i turn on a nordictrack treadmill exp 1000 x
they have a small switch Red in lower part to the side to the power cord.
see you instruction manual, or download free www. iconservice.com
God bless you
Jun 17, 2012 | Nordic Track Nordictrack Exp 1000...
I need a mannual for my nordictrack exp 10000 xI. Can you help?
Here is a list of many different versions of the NordicTrack Exp 1000XI. If you know your exact model number you can click on your version and view a parts list and purchase an owner's manual. If you just need to look at a diagram of all the parts many of the equipment pages have that available to view for free. Hope that helps.
Sep 12, 2011 | Nordic Track Nordictrack Exp 1000...
I have a Nortictrack Exp 1000 XI, with owners manual, but no Ifit activation code, is there any way to get that? Thank you in advance for your time, Sincerely, Mrs. Breen
The activation number is 1-866-608-1798, You will need the model and serial number to get it activated.
Hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Aug 16, 2011 | Nordic Track Nordictrack Exp 1000...
What can be the problem when motor does not start for nordic track model # NTTL9912.0
assuming there is power going to the motor. loose pwer connection or burnt out motor
Mar 06, 2011 | Nordic Track Nordictrack Exp 1000...
My exp 1000 sudenly stops , the counters reset to 0 all the lights are on but the control pannel is nonresponsive an error code 07 showed up once. Any ideas?
I don't have any suggestions for fixing it but I wanted to give you a resource should you need to purchase a new motor control board, you can choose your specific model and browse parts list here. Hopefully you can get it to work though, depending on the model it looks like a replacement can run you $100-$200.
Feb 21, 2011 | Nordic Track Nordictrack Exp 1000...
How do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Aug 01, 2010 | Nordic Track Nordictrack Exp 1000...
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
Nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
  • For questions about parts, service, user's manuals or non-working products, please call our NordicTrack Customer Service Department at 1-877-993-7999.
  • For questions about parts, service, user's manuals or non-working products, if you purchased your equipment at Sears, please call our NordicTrack Sears Customer Service Department at 1-888-825-2588.
Apr 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
1,576 people viewed this question
Top NordicTrack Exercise & Fitness Experts
NOEL
NOEL
Marvin
Marvin
john h
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
