Question about Adaptec Computers & Internet
What is TPM SYSTEM in Jeep Liberty 2005 - Adaptec Computers & Internet
Posted by peperamosche on
5 Related Answers
Denis Aube
  • 142 Answers
SOURCE: airbag light stays on 2005 jeep liberty
It probably will cost a few bucks to get the code reset, but you don't need to go to the dealership, most shops with a good scanner equipped for air bag code reading will be able to diagnose and reset the light. The most probable reason for the code is the battery being dead for a while, there is a capacitor in the airbag circuit to make sure the airbag can go off in a collision even if the battery disconnects itself in the process. There is a slim chance it might be something else but either way the shop should be able to tell you what the problem is, and get it fixed... But, just for fun, before doing all this, i'd disconnect the battery for 30 minutes to an hour and reconnect it back, some systems do effectively reset themselves this way.
Posted on Jan 13, 2009
michigan man
edgar walker
  • 3533 Answers
SOURCE: how to replace rear brake pads on 2005 jeep liberty
put the back of car on jack stands and secure the front tires so it does not roll and then remove the bolts off the back of the caliper there is normally two one at top and one at bottom and spray it with some kind of oil for rust and make sure you have the right size socket before you try to loosen them and once caliper is off and the old pads removed take one of the old pads and squeeze the piston on the caliper back in by using a "C" clamp and also remove some of the brake fluid from the master cylinder before you do this put the new ones back on and check the brake fluid and make sure it is full and then pump the brakes to make sure you have a good pedal also put some "No Squeak" brake stop on the back of the pads so they don't squeak they will have that where you buy the pads from
Posted on Mar 01, 2009
csmock132
Clint Smock
  • 4669 Answers
SOURCE: 2003 3.7 Liberty check engine light for crank sensor
2003 3.7 Liberty check engine light for crank....what? sensor? You have scanned it?
Posted on Mar 06, 2009
Richard Scordino
  • 6982 Answers
SOURCE: rear suspension,bushings,2005 jeep liberty
Generally the bushings aren't too expensive (likely about 25-30 each...But, unless you have done this kind of work, driving the bushings out and installing them can be difficult without a press. I've done many in-shop and its nothing like the ones I've done at remote locations using a hammer and chisels etc. You can do this yourself but I'd opt to do the r&r at home and have a machine shop do the actual bushing pressing. If you damage the arm ends you will need to replace the arm or do a bunch of bending to get the bushings back in place.
If you do have a press, than go at it!!
Posted on Aug 02, 2009
lloyd cole
  • 250 Answers
SOURCE: 2005 jeep liberty brake lights will not work. I
brake pedal switch, get a wire, unplug plug, bridge circuit and check lights.
plug and switch is high up on the brake pedal not normally easy to get to.
Posted on Aug 15, 2009
Abs not showing working on car tester, speedometer not working, check engine light on 2005 jeep liberty sport
You say the check engine light is on, if so there will be a system fault code, read that code with a OBD2 code reader
Sep 18, 2018 | 2005 Jeep Liberty Sport
Luz marcada con el numero cinco?
2003 Jeep Liberty- Reading Engine / Diagnostic Codes ...
? 1:13
https://www.youtube.com/watch?v=pGrPBBzp7wE
Jan 6, 2013 - Uploaded by DeathScouter
2003 Jeep Liberty- Reading Engine / Diagnostic Codes ..... error code will flash 2 times, brief pause, flash 1 time, pause, flash 5times, pause, ...
2005 Jeep Liberty possible cause of P0442 error. - YouTube
? 5:26
https://www.youtube.com/watch?v=2ba-gH0gadg
Dec 21, 2014 - Uploaded by TheBGravit
While replacing a bad fuel pump I believe I found the cause of a P0442 Error code. I was able to repair the ...
Jeep Liberty Questions - Cylinder Misfire code - CarGurus
www.cargurus.com > Questions > Jeep > Liberty
CarGurusMay 27, 2009 - My jeep Liberty 2009 does the same the Dashboard showed a code of cylinder .... i have a jeep liberty 2006 with the # 5 cylinder misfire. i replaced the sparks... I have a 2005 Jeep Liberty 6 cylinder, engine light came on scaned the ... 2002 jeep liberty camshaft posistion sensor error code p0340 5 answers.
Check Engine Light/Misfire Due to Intake Valve Locks ...
repairpal.com > Problems > Jeep > Liberty
Recently got a second hand 2005 Jeep Liberty Sport. Everything worked fine ... #5intake valve seat dropped and held open the intake valve. 2008 Jeep Liberty.
OBD-II Trouble Code: P0305 Cylinder 5 Five Misfire Detected
www.obd-codes.com/p0305
Dec 08, 2015 | 2005 Jeep Liberty
2005 jeep liberty diesel won't start
glow plug failure? read FSM on your system. and tests for it.
or
fuel filter packed up.
Apr 20, 2014 | 2005 Jeep Liberty
I live in Jamaica (no winter) can I remove the thermostat on my jeep liberty, 2005
Yeah it can safely run without a thermostat, but it will probably have a check engine light on later for code P018--engine temp too cold for too long. The engine will perform better with the thermostat and will get better fuel economy with the thermostat in place.
Jan 30, 2013 | 2005 Jeep Liberty
Front wipers dont turn on in 2005 jeep liberty
Fuse is good -- continue your testing on the other wiper
system components
Need a wiring diagram to know what you have & what
you want to test
Nov 25, 2012 | 2005 Jeep Liberty
PO700 Transmission control system malfuntion Jeep Liberty 2005
since that particular tranny is heavily computer controlled you need to hook the car up to a diagnostic computer for that problem.
May 28, 2011 | 2005 Jeep Liberty
Computers & Internet Logo
108 people viewed this question
Top Adaptec Computers & Internet Experts
John Dio
Level 1 Expert
Robert Graf
efs_perpends
efs_perpends
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
