Kohler 12 kW Emergency Power System - 12RES-L Logo
Posted on Feb 18, 2010
I have a new Kohler 12kw res generator on propane - backfiring
I have a new Kohler 12kw res generator on propane it backfires and runs rough. Had the serviceman out last week, he changed the plugs and adjusted the second stage regulator. It ran ok untill the next time I tried to use it - now it is backfiring again.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5245
Points
5
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7176
Points
Did you put the propane orifis in and unplug the spark wire
3answers
What's causing the back fire?
Question edited for clarity and spelling.
Question moved from Motorcycles category.
Guessing a sticking inlet valve or slipped timing.
https://www.google.com/search?q=lincoln+ranger+225+backfiring+engine
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
Kohler backfires
This is a timing issue. Check the flywheel to make sure that it is not loose and that the woodruff key is still present.
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
81 honda accord runs real rough and backfiring out of carb
That is a car not a motorbike. Bikes only have 2 wheels. But you may want to set up the cam and ignition timing. it is only timing that will cause backfires.
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
2helpful
3answers
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
