Battery light and brake light were on, car wont run on driver or reverse, car wont startnow
It is problem with alternator , call technician he repair it and, he will put your battery to charge for min 8hr, then you can drive your car. when ever battery light is on it means battery is not getting charge.
Alternator died, so you were only running on power from the battery which killed that so now you will most likely need to replace both. the brake light could be on because of low brake fluid or the electronic fluke
Nissan truns the brake and battery light on when there is a charging issue. When you say it wont start does that means it craks or no? If it does not crank I would attempt to charge the battery then try to start it and check the charging system.
