Sewing Machines Logo
Posted on Feb 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My top stitch is flat, but the bobbin is bunching and looping extra thread. cotton fabric, polyester thread
Anonymous
Level 3:
Genius:
  • Master 1,116 Answers
  • Posted on Feb 20, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1116
Questions
0
Helped
371612
Points
3174
What looks like a bobbin problem is sometimes the threading of the top thread.
If you threaded the machine with the presser foot down, the tension is closed and the thread cannot enter as it should.
Improper seating of the thread into the tension results in loopy stitching as the thread is not being guided at the proper tension to create a satisfactory stitch.
Try re-threading the machine with the presser foot up.
2answers
I cannot get the perfect stitch to sew cotton polyester. It seems like the red thread is loose loops
Check you tension if bottom thread loopy it's the spool try re threading machine. And change the needle
1helpful
The stitches on the underside are looping I’ve retreaded both the needle and bobbin and neither makes a difference
You are getting a thread mess under the fabric? Frequently, this occurs because the top thread is not fully seated in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the machine from the beginning.
If necessary, adjust the top tension so the top and bobbin threads meet in the middle of the fabric.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
TIP Avoid Thread Bird Nesting with these Four Tips Stitching Sewcial
Troubleshooting Thread Nesting Sew Toot
1helpful
2answers
I am a new sewer have a Brither BM-2600 what numbers on the dial do I have for just plain stitching I have tried lots of combinations but the cotton underneath is all bunching up and not sewing right
I am not sure as to your machine, are you saying a "brother" machine? If your tension is set, say on 6 and it is too tight, turn the dial one more number......to a 7 or to a five and then check again. Also, I would rethread the machine and also take the bobbin out and then put it back into the machine. A lot of times, the bobbin isn't threaded into the machine correctly and it bunches up. Also, you can't use certain thick thread on some machines.
1helpful
When i first start sewing the thread will bunch up and make a rats nest how do i stop thisa
That is called thread nesting or bird nesting--or what I like to call thread "barfs."
Be sure to ALWAYS RAISE the presser foot when threading the top thread. This releases the tension disk so the thread will seat completely.
Bring the bobbin thread to the top of the fabric and gently hold both thread tails in your left hand while taking the first stitch or two. It may be beneficial to manually turn the handwheel for the first couple of stitches. It also helps to have the take-up lever at it's highest point BEFORE starting to stitch.
What causes Bird Nests Superior Threads
How and Why to Bring up the Bobbin Thread
3answers
Threads bunching up on singer 7256 when i start sewing
1. I believe that your bobbin tension is too tight.
2. Your top tension should be at about four.
3. When you do your top threading check the tension before threading the needle. It should have some tension but it can't be too loose. Do this with the foot down.
4. If you have adjusted the bobbin more loosely replace it and turn the hand wheel with some fabric in place. It should come out with a nice stitch. You may have to do very small adjustments to the top tension to make the stitch perfect.
1helpful
The tension on my machine is off.I don't know which thread to adjust.bobbin or top thread. on fabric top stitch seems ok,bottom stitch bunches up and is loose.How do I readjust the tensions?
If the thread problem appears under the fabric, it is a top thread issue.
If the thread problem appears on the top of the fabric, the bobbin thread is the issue.
Perhaps the upper thread is not seated completely in the tension disk. Remove the upper thread from the machine, ALWAYS RAISE the presser foot, then rethread from the beginning. Make sure the thread path is correct. Test your stitch.
If the thread is still looping under the fabric, the upper tension is too loose. Set the upper tension to the midway point. Test and adjust the tension until it is where you want it. Preferred tension is when both threads meet in the middle of the fabric.
sewing machine tension Google Search
I've tried everything but cotton keeps on looping from under the material
Make sure you are using a brand-new needle and that is installed with the flat side facing the correct direction.
Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread the upper thread. Verify the thread path is correct. Set the thread tension at the midway point between high & low number.
Lower the presser foot, retest the stitch quality on scrap fabric and adjust the upper thread tension until the upper thread and bobbin thread meet in the middle of the fabric.
Understanding Thread Tension Threads
Needle stitch fine. Bobbin stitch loops.
First, try a brand new needle.
Second, consider using a better quality thread. By all means, AVOID old or bargain bin threads. Coats & Clark used to be a standard, but thread quality has improved over the past few years, so you may want to check out other brands like Aurafil, Superior, Isacord, etc. Also, cotton wrapped polyester thread releases thread lint that contributes to build-up of gunk in the machine. Some sewists have noted that they experience more sewing issues when using C&C threads. However, some machines will do better with certain thread brands than others, so some experimentation may be beneficial.
Third, check the stitch on your sample again. Generally, when thread loops appear on the underside of the fabric, it is the upper thread that is the problem. If loopy threads appear on the top of the fabric, it is the bobbin thread that is the issue. You can even use a different color in the top to help distinguish which thread is the problem.
Fourth, when threading the upper thread, Always Raise the Presser Foot during the threading process so the tension disk is released and the thread can seat properly. "Bird nesting" occurs when the thread is not seated in the tension disk.
Fifth, when the upper thread appears on the underside of the fabric, the upper thread tension is too loose. If the bobbin thread appears on the top of the fabric, the tension thread is too tight (or the bobbin thread is loose). Start out with the upper tension set at the midway point and tweak it from that point. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Also, remember that tension is not static--a tension setting for chiffon will most likely not work on cotton or denim. Get comfortable adjusting the tension to suit the project you are sewing.
I need elp with tension on singer cg550
You didn't explain the symptoms. Is the thread bunching, looping, knotting under the fabric? Is the bobbin thread rising to the top of the fabric?
If it is bunching under the fabric, it is probably what is called thread nesting or bird nesting. There are several fixes, sometimes more than one fix is required to resolve the issue.
Be sure to clean under the needle plate, around the bobbin, and the feed dogs. If the machine has instructions for oiling, follow the directions using a fresh, good quality sewing machine oil and apply only 1-2 drops each spot.
Install a brand new needle. Make sure you are using a needle compatible with the thread and fabric being used. All About Needles
Best practice is to use the same thread in both the upper and bobbin. Also, avoid old or bargain bin thread. Spend an extra couple of dollars to reduce frustration and increase success with your machine. If you wish, you may use two different colors of thread to test so you can easily determine what is happening with the tension.
Remove the thread from the machine. RAISE the presser foot and rethread from the beginning--the thread needs to be seated firmly in the tension disk. Verify that the correct thread path is followed (consult the owner's manual).
Set the upper tension to the midway point between high & low numbers (this is the factory standard and is a good place to start, but every machine is different and may need adjustment).
Confirm that the bobbin is installed in the bobbin case (turning the correct direction) and that the bobbin case is threaded properly.
Before beginning to stitch, hand rotate the handwheel one rotation and pull the bobbin thread to the top of the fabric. Then, gently hold the thread tails in the left hand and slowly begin to stitch.
Test.
If thread is bunching, looping under the fabric, the upper tension is too loose. Tighten it and retest. On most machines, the lower the tension number, the looser the tension.
If the bobbin thread is rising to the top of the fabric, the upper tension is too tight. Loosen the upper tension and retest.
Keep adjusting and testing until it is where you want it. Generally, tension is correct when both threads (upper & bobbin) meet in the middle of the fabric. FWIW, tension is static and should be tested and readjusted every time a new project is begun. The needle, thread, and fabric will affect the tension, so it is important to get comfortable adjusting the tension.
Also found the following reviews. Appears that some users have had tension issues with their CG550.
Amazon com Customer Reviews Singer CG 550 10 Stitch Commercial Grade...
When i run a straight stitch, the top of the fabric looks well sewn; the thread on the bottom of the fabric, however, bunches up-it looks nothing like the top stitch.
Is it really the bobbin thread that is bunching under the fabric, or is it really the top thread that is creating loops and "bird nests" under the fabric???
Rethread your upper thread. BEFORE you thread the upper thread, be sure to RAISE the presser foot. This releases the upper thread tension disks so the thread is firmly seated in the tension disk.
If it continues to be a problem, then the upper tension needs to be tightened. Adjust slightly, then test. Repeat until the upper and lower threads meet in the middle of the fabric.
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
