this site has the specs for your tablet, but it doesn't appear to be either 3G or 4G capable it does have a slot for a micro SD card
http://www.pcworld.com/product/1430414/zeepad-7drk-tablet.html
There are some possible solutions:- 1. Check that your sim card is in perfect condition by putting the same sim card in any other mobile if the samemessage appears that means the problem is in your sim card 2. Check that your sim card's slot is in perfect condition by inserind any other sim in your sim card's slot if the same message occurs that means the problem is in your sim card's slot 3. Check that whether you are inserting your sim card correctly or not
The SIM card in the iPhone is removable, but it's hidden. To remove the SIM card, you need a paper clip.
We are checking to see if this voids your iPhone warranty. If you are concerned that it might, please don't perform this task.
The iPhone's SIM card is located behind this door. 1. Locate the SIM Card Slot
The slot is located at the top of the iPhone, between the headphone jack and the power button. The paper clip is a valuable tech tool. 2. Open the Slot
Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up. 3. Remove the SIM Card
The SIM card is in a cradle. You can pop the card out of the cradle.
To replace the SIM card, put the card back in the cradle. The cradle
and card are notched in a way that forces you to replace the card on
the proper side. Then just slide the card back into the iPhone.
first remove the sim card and then switch on the phone... then choose antenna on... after a few seconds you will see emergancy only on your screen ... turn off your mobile and insert the sim and switch it on again ... this solved my problem ... but this is not working on my cell now..
does anybody have a solution?
