IF DISPENSER IS CLOSED WHEN FINISHED COMPLETE CYCLE .
THERE ARE TWO WAYS THAT D/W'S
OPEN THE DISPENSER ONE IS BY WAY OF TIMER TRIPPING LATCH, OTHER IS BY WAY OF BIMETAL IN THE DOOR. THE SOLID IS BECAUSE OF THE MOISTURE ABSORPTION OF THE SOAP. THIS IS ASSUMING THAT YOU HAVE NOT BLOCKED THE DISPENSER DOOR WITH SOME OBSTRUCTION.
Hi
Dishwashers use Bi-Metal strip to
allow the dispenser to open/close. This strip when heat up causes the soap door
spring to open up the dispenser. If this strip is not heated doesn't allow the
door to open. The strip may not be getting 120V or maybe disconnected. Newer
(plastic liner) dishwashers use a wax motor to open the soap dispenser. The
plunger inside the wax motor slowly moves and pushes the plunger and door
open. And, if this wax motor doesn't receive 120 volts, then it'll not work.
Please check the voltage to the wax motor/Bi-metal strip; also inspect the
connections to these.
Hope this helps...
Daniel
Daniel
