Panasonic Panafax UF-560 Plain Paper Laser Fax Logo
Posted on Feb 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The code error 021 comes always back on our fax What to do? I did really everything!
Michel Smith
Level 3:
  • Master 1,218 Answers
  • Posted on Sep 24, 2010
Michel Smith
Master
Level 3:
Answers
1218
Questions
Helped
795365
Points
2925
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Feb 18, 2010
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1006898
Points
9738
Turn the machine off at the rear
Pull open the doc feeder
hold down the pointed switch by the skinny glass piece while
turning on the machine
scroll down to SHIPMENT SET
press set
press 2
wait for the machine to reboot
Remove Error code 021
Press
Function
7
monitor slowly 4 times
6
set
wait for the fax to initialize and come back to READY
1helpful
2answers
We are getting Error CODE 021 on our fax machine Panafax UF-560 and can't find the owners manual to fix it...can you help?
Error code 021 indicates a bad fuser but in some cases, the error can be reset. To attempt a reset, do the following:
  1. Remove the toner cartridge and close door back up.
  2. Power down the fax (switch is on the back side lower left) for 5-10 seconds.
  3. Power on the fax and see if the 021 code is gone.
  4. Re-insert toner cartridge
If this doesn't work, there's one other thing to try prior to calling a technician.
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax
If this doesn't work, a service call will be needed to replace the fuser. I do hope this fixes your problem.
(reset information courtesy of Eliot at howtomendit.com)
13helpful
3answers
Error code 021
Press
Function
7
6
set
4helpful
3answers
Toner was changed, m/c powered,and instead to ready it was showing ERROR 021
Function 7 press monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax machine to reboot
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
2answers
Panasonic uf885 error
Same here. I replaced the fuing unit but he error code 021 still is present.
22helpful
8answers
Code error 021 not in book inforation codes
3. Push Monitor button 4 times (it will only beep at you - nothing will appear on the screen) - so count the beeps)
13. Power on the fax (and cross fingers)
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
