Question about Xerox Phaser 8500/DN Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Posted by info43977 on
Clive
  • 4,345 Answers
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Posted on Feb 18, 2010
Whit
  • Xerox Contributor
  • 185 Answers
You should replace the inkloader 133K27771, unless the error goes away.
Posted on Mar 16, 2010
Nathaniel Berrios
    New Friend:
  • 71 Answers
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Testing the Ink Out Sensors Use this procedure to test if an Ink Out Sensor's flag works correctly.
1. Remove ink sticks from the ink loader's channels.
2. Place the printer in Diagnostics Mode by:
Customer method
a. While error code displayed, press UP arrow and OK key.
b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
c. Select test 82: Monitor Sensors. Press OK.
d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel.
1. If the sensors are not working properly, follow standard service procedures and replace the ink loader assembly.
If Genuine Xerox Phaser 8500/8550 Ink Sticks are being used, check for defects in the ink sticks and replace. If no defects are found, replace the ink loader assembly. · If Phaser 8400 Ink Sticks are being used, they will not properly actuate the ink loader sensors. Do not use Phaser 8400 ink sticks in a Phaser 8500 or 8550 printer.
· If non-Xerox ink is being used, the shapes of these sticks are different than genuine Xerox Phaser 8500/8550 ink and may not properly actuate the ink loader sensor(s). Remove all non-Xerox ink and re-load with genuine Xerox Phaser 8500/8550 ink and check sensor operation. If proper function returns to the printer, the false error message was caused by the use of non-Xerox ink. If the false error message continues, replace the ink loader assembly.
2. If the ink out sensors work correctly, identify the ink stick(s) being used in the printer.
1 Related Answer
StevenC82
Steven C
  • 160 Answers
SOURCE: xerox phaser 8560 error 09:038:46:25836
That error code indicates a problem with the ink loader, 09.038 is the black chute. Make sure you are using genuine Xerox ink sticks and that the chute is clear of debris. Next enter Service Diagnostics mode by powering on the machine and hold the back and help buttons at the same time as it boots until it says it is beginning service mode. Once the menu is displayed, go to function, clear ISC Fault and press OK. If this hasn't fixed the problem you will need to replace the ink loader, part # 133K27771. You can buy one here. I will be making a video on how to replace this part later this week, if you need it let me know. - Steven
Posted on Apr 13, 2011
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Error code 07,015,48:94562
That error signifies the head tilt restraint is out of place. There is a kit that solves this error, the part number is 8560-Z2. http://www.iteminconline.com/itemdesc.asp?ic=8560-Z2&eq=&Tp=
2answers
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
P/N FOR pHASER 8560 DISPLAY PANEL
P/N for Phaser 8560 printer is 802K93650
2answers
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Xerox Phaser  8500/DN Printer Logo
Top Xerox Office Equipment & Supplies Experts
Ekse
Mehandi Husain ...
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
