Hoover Nextra HNF 2137 Front Load Washer Logo
Question about Hoover Nextra HNF 2137 Front Load Washer
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hoover Nextra HNF2127 washing machine. After cycle has finished the start and pre-wash light are flashing (every 15 seconds) and the door is still locked. The clothes are still wet and are not warm after I get the door open. What does this indicate is the problem?
Posted by xpaddler on
Anonymous
  • 8,619 Answers
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
Anonymous
My creda nhf-2127 wont star a cyle the machine come on wont do a wash
Posted on Apr 10, 2011
Hoover Washing machine hnwf 6135 start and delay time blinking
Turn it off at the mains. Leave it an hour and start again.
Here is your manual in case you need it
https://www.manua.ls/hoover/hn-6135/manual
and even a 1 hour video :>)
Hoover Nextra HNWF6135 Washer Dryer - YouTube
https://www.youtube.com > watch
1:03:21 this is another of your choice! hoover nextra doing a cotton 40. please take a look at my amazon.
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
17helpful
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
1helpful
2answers
Fabric conditioner still in compartment after wash
Most washers recommend dilluting the softener with water when you put it in the compartment. It can build up and completely block it. I've had to manually remove it with anything I could find to reach it and since I've started dilluting it have had not problem.
16helpful
3answers
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
3helpful
2answers
My washing machine is not finishing a cycle and is not pumping out the water. It will start a cycle, but then it will stop half way through, and the "delay/start" button will flash red. Please help
i had same issue turned out pipe was blocked and washing machine gave up trying to get rid of water, so would stop, cleaned filter, uncloged drainig pipe and was good to go
Top Hoover Washing Machines Experts
Steve F
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
