i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
There's a fuse panel either under the seat or behind the triangular plate on the left side of your bike. If you find a fuse blown or the main circuit breaker tripped, you'll have to figure out what caused it.
The sound your heard could have a fuse poping. If you accidently arched something out, then the fuse should be the first thing to go. should be an easy fix. First try and locate your fuse box. , or any fuses. take off your seat, and remove the side covers to find the fuse box. Hope this helps.
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
