Epson Stylus NX300 All-In-One InkJet Printer Logo
Posted on Jul 19, 2017
EPSON Stylus NX300 works for copy...but not for print from comput
Hi
My EPSON Stylus NX300 works very well when copy...Scanner works very well however ....Hoever when I want to Print texte from my Computer it doesnt work. I did removed softwre from computer 4 times and installed 4 times from Epson site software. Unplugt power for 1 hour...didnt help..disconnect Epson cable from PC 4 times ..didnt help ... Can you help please. Thanks for your help and cooperation
Allan
5 Related Answers
Anonymous
  • 63 Answers
  • Posted on Feb 07, 2008
SOURCE: Scanner not recognized by computer
Try to check control panel>device manager>check if there is an imaging device on the list. If none, it means that the computer is not detecting your printer. Try to plug it in to other port or try to use another usb cable. If still won't work, you need to uninstall and reinstall the drivers for the scanner
Anonymous
  • 848 Answers
  • Posted on Jun 22, 2008
SOURCE: epson stylus 680 injet printer
try this
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
Anonymous
  • Posted on Feb 24, 2009
SOURCE: Epson RX425 multifunction
Just cracked it, had same prob...printer would print but wouldn't scan
lost original CD...tryed epson downloads but not the older versions...
i needed the 2.6 version
TRY THIS
http://driverscollection.com/?file_id=24466
Anonymous
  • 163 Answers
  • Posted on Apr 03, 2009
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Anonymous
  • Posted on May 15, 2009
SOURCE: scanner not working cannot find scanner WINDOWS XP
Cannot scan  on IMac with Epson Stylus CX3900?
My Epson NX300 prints just fine from anything on the computer screen but, when I try to print a copy from a copy in the printer/scanner tray the paper from the supply rack drops about 4 inches like its...
Connect the scanner to an old USB HUB, and it will work. It stops when you connect to a new USB connection direct in a new PC. Done it. I worked with a 2 port USB HUB. Was posted someplase but I cant remember where. Magnar Vereide Datainstituttet.no
Why does my Epson Stylus NX300 print a rainbow color band at the bottom of vertical 4x6 pictures
DOES THIS COLOR SHOW UP ON YOUR PRINT PREVIEW?
IF NOT, THAN GO INTO PRINT CARTRIDGES ON YOUR COMPUTER AND CLEAN THEM UP!
THAN DO A TEST ON A SEPERATE PIECE OF PAPER THE SAME PICTURE TO MAKE SURE IT HAS STOPPED WITH THE RAINBOW PROBLEM YOU'RE HAVING.
YOU MAY ALSO HAVE PICTURE SETTINGS WRONG ON YOUR COMPUTER, YOU CAN CHECK THESE UNDER PRINT PREFERENCES.
IF NON OF THE ABOVE WORK, THAN TAKE YOUR PRINT CARTRIDGES OUT AND CLEAN THE CONTACTS WITH SOME RUBBING ALCOHOL AND A Q-TIP.
1helpful
I HAVE A EPSON NX300 ALLINONE PRINER.I WOULD LIKE TO PRINT ONLY WITH BLACK INK?WHAT DO I NEED TO DO
When you try printing any file or document, a printing properties option appears.
In this option, you have choice to print only with black colour.
Out of Magenta but just want to print in black and the Epson nx300.won't let me.
strangely enough, epson printers require all cartridges to have ink in or they don't seem to work.
1helpful
How to print 4x6 pictures on a nx300
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Epson-Stylus-NX300-All-In-One-InkJet-Printer-manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Epson Stylus NX300. I send a FAX and the folks on
check first if your printer can copy well. try to photocopy a document. and if it copies well, that means, its a problem on the part of the receiever, if it does not copy well, that means the scanner of your unit has a problem.
1helpful
I have a new Epson Stylus NX300 Series. When I
Diane,
We try to steer people away from new Epson printers unless they plan on purchasing a professional model. The new Epson cartirdges have little ink and finicky. I would try power cycling the machine with the cartridges removed (unplug it for 30sec.) then reinstall the cartridges. If the problem persist call Epson and let them know what you think. If they don't help you, buy an HP. But but an HP that takes integrated print head cartridges or you'll be in the same situation.
Pat.
The 'EPSON Scan' desktop icon on my computer won't work.
Hopefully this is stilll relevant to somebody, but if you run the program as administrator you can get in
No epson scan icon
1. Make sure you have the latest drivers and software installed. (see attached link)
2. Search for the scan tool using your operating system. (In Windows for example you press the "windows" key and the key "s" simultaneously on your keyboard and just type "scan". You should get a list with all matching results.)
Epson Stylus NX300
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
