i know how to load music to sandisk sansa player.
NOTE: If you're using a MAC, see answer ID 1141
METHOD 1 -
Load and sync music files using Windows Media Player
METHOD 2 - Copy & paste or drag & drop music files to the player through "My Computer".
1. Connect the Sansa player to the computer.
2. Double-click
My Computer.
3. Locate and select the music file(s) to be copied to your Sansa player .
NOTE: You can select multiple files by holding the CTRL key down while clicking files. You can also select all the files on that particular folder by holding CTRL key then pressing A.
4. On your keyboard, hold the
CTRL key then press
C to copy.
5. Under
My Computer, double
-click the Sansa player.
NOTE: If the Sansa player is connected in MSC mode, you will see something similar to the image below:
If connected in MTP mode, you will see something similar to this:
6. Locate the
Music folder and double-click to open.
NOTE: In MTP mode, you may need to double click on Internal Memory
to get to the MUSIC
folder.
7. Hold down the
CTRL key on the keyboard then press
V to paste the music files.
If you want to enjoy more music and video on
Sansa Media Player, you can try this guide.
