The blue ray player and tv have different inputs. Unless you are using a cable box, dish or whatever, you can try hooking it up with the same cable.
But sounds like your tuner card may be bad. I have seen it a few times. Is there any other way you can hook this up without the input you are using for tv?
Sounds like you may have bad inputs on the HT-CT100. Most due to faulty capacitor(s), resistors, that control the input.
the bue ray works on all tv inputs and all theater system inputs?
The comcast box works on tv but not theater system?
Is this correct?
Unless you can find another way to hook it up. I would hook box to tv and then tv to theater system. That should work out for you. Mabey the theater system needs a firmware/software updated or doesn't support that type of signal. Not sure, haven't heard of one like this before. I would try hooking comcast to tv, then tv to theater system, should work out well this way.
Not a problem! Thank YOU!
If I hook the cable bow up to the tv directly with HDMI it works fine. But once I run it through the HT-CT100 the picture and sound go away. Any other thoughts? Thanks
If I hook the cable box directly to the tv it is fine via HDMI, but if I run the HDMI through the HT-CT100, then the picture goes in and out and the sound is gone
Even though the blu-ray works on all three inputs?
Correct. At first I thought it might be an HDCP problem, but I confirmed Comcast has HDPC.
i will try that. However, I just tried hooking it up again, and if I have the tv set to HDMI 1 with the the cable in HMDI 2 then I get 5.1 sound, but if I switch to HDMI 2 then I lose sound and get an intermittent picture.
Thanks MNfisherman!
