Question about Samsung PCL541R 54" Rear Projection Television
Samsung projection tv. tv went off, timer light is light. worked for a while the next day.can't turn on with button or remote. could this be a bad bulb
Posted by haasdmd on
Edward
  • Samsung Master
  • 3,459 Answers
Its probably shorted convergenc chips. You can get the parts and instructions from www.TvRepairKits.com
Posted on Feb 21, 2010
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Samsung HCN5529W projection tv. The
yeah plenty, on older rear projection t.v.'s the circuit boards tend to over heat as they get older. keep the t.v. off and unplugged. contact a local repair shop.
Feb 20, 2009 | Samsung HCN5529W 55" Rear Projection...
Samsung PCL545R Projection TV
Pull out the plug for the TV and leave it out for one hour at least.  Plug it back in and it should be ok.  It will re set itself.
Sep 30, 2008 | Samsung PCL545R 54" Rear Projection...
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Samsung PCL541R 54" Rear Projection Television Logo
405 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
