Question about Zenith ZDA311 DVD Player
How do you get DVD picture to show up? Power is
Hi! I haven't used this DVD player in a couple of years, so I may be forgetting something. I've got my cable on and TV is showing regular TV programming. Then I put the power for the DVD player on, and load a DVD. I press the "play" arrows and I see the number counter going up, but the picture on the screen is still the TV show, not what's on the DVD. I have tried changing the TV channel to 2, 3, 4, etc. and that doesn't work. How do I get the DVD picture to show up?
Posted by jjq333 on
electronic & computer repair& servicre
  • Zenith Master
  • 12,061 Answers
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Posted on Feb 18, 2010
Anonymous
    New Friend:
This same thing happened to me. Have you pushed the button on your TV marked "Video"? That was all I had to do to get the DVD movie to play.
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Nikkon s70
Save yourself the aggravation 03/25/2011 MommybrainX2 rating.png My hubby bought this for me for Christmas. It was to replace my OLD Cannon (4 MP). Now he feels horrible for buying it for me! This camera is horrible! I read the manual, I've played with all of the settings- the fact is when trying to take a picture of a moving object- even slightly- the picture comes out extremely blurry. Forget it with a toddler. I have yet to get one good picture of my kids with this camera, which was the whole purpose of having it. My old 4mg camera takes better pictures than this thing does. Settings haven't made a difference. I have actually reverted to my old camera instead of using this sad excuse for a camera.
Jan 15, 2012 | Nikon COOLPIX S70 Digital Camera
Hello. My DVD player will not play past the first few seconds of DVD. I've tried with 3 different disk and the same thing happens. I've cleaned all disk and still haven't been successful....
What I can think of the Lens inside your player may have dust etc on it.
If you have a CD/DVD Lens clearer disk try that, Then see if you can get it working better.
Jul 28, 2011 | Televison & Video
I accidentally selected a wrong video option & now there is no picture. I cant reset it without a picture to guide me through the steps.
Hello
I thinks that you haven't its user manual with you now. If have, refer to it. All the proceedings are there. If you haven't one, either send your Email address to me by Fixya, or get into the URL I've given below, where you can download the maual of your set as Adobe PDF document. OK
Wish You Happy Easter.
www.retrevo.com > JVC Manuals > JVC DVD Players Manuals
Apr 15, 2011 | JVC XV-N320 DVD Player
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
No power
Hi
Check the fuse for it if you haven’t yet.
May 22, 2009 | Rosen CS700DVD Car Show 7.0 7 Inch...
LG dvd player DP281B shows disc error
if you have USB PORT. JUST remove the disc from dvd unit and plug in a usb pen drive with usb port.
if you haven"t.USB PORT JUST BUY IT FROM LOCAL ELECTRONICS SHOPS AND FIT WITH YOUR DVD player.
Oct 22, 2008 | Electronics - Others
No picture
Lately I cannot get a picture when I turn on the DVD operation--the TV screen, as always, is on INPUT (Extension).....the unit show PLAY, but the picture does not appear--and the TV screen stays blue! The audio is on, but no video....
This is something rather recent. However, if I unplug the electric-power source for the DVD-player, then sometimes the picture does appear, though not always.
I have checked the manual but find no good answer there. Please let me know what to do....many thanks.
Aug 06, 2008 | GoVideo DV2150 DVD Player/VCR
My DVD player, stopped playing in color!
check to see if the coding is set to PAL or NTSC, when watching in PAL, NTSC shows up in black and white. ( NTSC is normal for the USA and a hand full of other countries... PAL is used in ASIA, EUROPE, and most everywhwere else).
Oct 18, 2007 | Panasonic DVD-S29 DVD Player
Zenith ZDA311 DVD Player Logo
189 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
