Question about Toshiba 32AV500U 32 in. LCD HDTV
Picture ok but loss of sound with high pitched buzz
Periodically after the television has been on for about 8 hrs the picture continues as normal but the sound goes and a high pitched buzz comes on. The only way we can get rid of the buzz is by turning the television off and putting it back on. any answers please help!
Posted by lesleyann36 on
Chi Chu
  • Toshiba Master
  • 8,457 Answers
Power board have problems.Take the tv aparts put some super glues on all around the transformers.Will help lower the buzz alots or stop it completely.
Posted on Feb 17, 2010
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
A loud buzzing is coming from the back of my sanyo ds 25390 tv. picture and regular sound is fine
If it is a high pitched whine or buzz it is likely a transformer vibrating so hard it is making the noise.
There are ways to try to deal with this issue but the set has to be opened and probed to locate where it is coming from--
for example with back off and set on a plastic rod can be used to touch areas and exert slight pressure until the sound changes or goes away--then either replace the part or I have used hot glue etc to stop it.
You first have to locate the source of the issue:
find where it is coming from.
Mar 24, 2012 | Televison & Video
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
No picture and blinking light consistently
Do you hear clicking or like wanting to turn on? it could be the ballast which is the board that powers the lamp .Do you hear buzzing ,whirling or like a high pitch sound? If you do it could be an issue with the color wheel.If you don't hear any of that and tv is between 1-2 yrs then most likely it's the lamp that needs to be replaced.Your Original lamp is Osram and last 4000-5000 hrs, get the Philips which will last 2-4 yrs 6000-8000 hrs.God bless you!
Oct 01, 2009 | RCA Televison & Video
High pitch screech w/no signal
is this a picture tube type of tv? big in back? If so, it could be the tube/circuit short.
If it flatpanel, it could be a bad capacitor in the DM or "Y" board or even possibly faulty power supply. Further testing will be necessary
Jul 22, 2009 | Polaroid FLM-3732 Television
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
High Pitched Noise
most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise continue.you will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Jun 11, 2007 | Toshiba 27A41 27" TV
Toshiba 32AV500U 32 in. LCD HDTV Logo
365 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
